GSR motor swap motor mount
Old Apr 22, 2004 | 03:30 PM
shadykit's Avatar
Default GSR motor swap motor mount
Hey fellas, if I do a 99GSR motor swap into a 96 civic HB, can I use the GSR motor mounts or would I need aftermarket mounts??
Would after market mounts be helpful at all?
Old May 1, 2004 | 05:34 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: GSR motor swap motor mount (kitchale)
Someone correct me if I'm wrong here since I'm more of an EG tech guy.
Timing belt side bracket and mount needs to be from a 99-00 Civic Si
Topside tranny mount can be the stock Civic mount
Front mounting brackets needs to be 99-00 Civic Si, front rubber mounts can be stock Civic
Rear tranny/motor bracket needs to be 99-00 Si, mount can be stock Civic
Again I'm *pretty* sure of this, not 100% positive as I've done EG swaps and only witnessed EK swaps at my shop.
Old May 1, 2004 | 09:01 AM
Travis.EK's Avatar
Default Re: GSR motor swap motor mount (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Someone correct me if I'm wrong here since I'm more of an EG tech guy.
Again I'm *pretty* sure of this, not 100% positive as I've done EG swaps and only witnessed EK swaps at my shop.</TD></TR></TABLE>
You are correct.
Old May 1, 2004 | 09:14 AM
The Internet Tough Guy's Avatar
Default Re: GSR motor swap motor mount (Travis.EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Travis.EK &raquo;</TD></TR><TR><TD CLASS="quote">You are correct.</TD></TR></TABLE>
not really
you're close...
just the bracket. you reuse the mount
correct.
you need the lower front bracket that bolts to the tranny from any B series. use a 96-97 Del Sol VTEC AC bracket if you want to keep your ac; otherwise, you can use the integra one. the stock mounts are reused.
yup.
all you need is:
99-00 Si Rear Tranny Mount bracket: 50827-s04-n10
99-00 Si Driver Side mount bracket: 11910-p30-000
and the 2 front lower brackets on the engine & tranny.
you can reuse all other mounts and harware on your car.
Modified by jwn7 at 2:42 PM 5/1/2004
Old May 1, 2004 | 10:08 AM
deSigi's Avatar
Default Re: GSR motor swap motor mount (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">all you need is:
you can reuse all other mounts and harware on your car. </TD></TR></TABLE>
You can actually re-use your front lower bracket on the engine from your 96.
jwn7 I don't know if that's what you meant?
The front lower bracket on the tranny though needs to be from an Integra.
Old May 1, 2004 | 10:25 AM
miahmouse's Avatar
Default Re: GSR motor swap motor mount (e-kay)
if you want to keep ac you have to use a del-sol vtec bracket for front drivers side (where ac mounts....)...
Old May 1, 2004 | 10:49 AM
Default Re: GSR motor swap motor mount (miahmouse)
can you really reuse the D series bracket if you don't keep the ac compressor? i didn't think so... if you want to keep ac you need the 96-97 del sol bracket.
6th gen swap guide: http://www.phear7imports.net/subs/btroop/trey/6gen/
Old May 1, 2004 | 11:00 AM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">can you really reuse the D series bracket if you don't keep the ac compressor? i didn't think so... 6th gen swap guide: http://www.phear7imports.net/subs/btroop/trey/6gen/</TD></TR></TABLE>
no, the d series bracket won't bolt to **** on the engine. b-series bracket for no ac, or del-sol vtec if you want ac.
some have said you can use any b series and just use two compressor bolts, they soon found themselves with two broken bolts and a f'd up compressor...
Old May 1, 2004 | 11:14 AM
RTE117's Avatar
all you need is:
Modified by jwn7 at 2:42 PM 5/1/2004</TD></TR></TABLE>
Correct, if he's saying what I believe he is. I used the Si rear tranny bracket and Si drivers side bracket, I used all the original mounts. The A/C mount was never used and the passenger side mount and front tranny one remained. I think, it's been awhile.
Old May 1, 2004 | 11:43 AM
deSigi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">no, the d series bracket won't bolt to **** on the engine. b-series bracket for no ac, or del-sol vtec if you want ac.
some have said you can use any b series and just use two compressor bolts, they soon found themselves with two broken bolts and a f'd up compressor...</TD></TR></TABLE>
Sorry, I was misinformed to begin with. Any B-series mount will fit on?
Old May 1, 2004 | 11:47 AM
any 94-01 integra, 99-00 si, will work if you don't want your ac; use a 96-97 del sol VTEC bracket if you want it. simple as that.
and to the original poster, aftermarket mounts are great. HAsport makes nice kits but they're a little expensive. i have the 3 mounts from jimfab.com, and they're awesome. almost 0 vibrations over stock and the engine barely moves. you could also fill your stock ones with window weld or get some poly inserts from energy suspension.
Old May 1, 2004 | 12:55 PM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">any 94-01 integra, 99-00 si, will work if you don't want your ac; use a 96-97 del sol VTEC bracket if you want it. simple as that.
sorry, should've been a little more elaborate...
lyzer227
Jul 6, 2009 01:44 PM
THugluv423
Mar 23, 2005 07:55 PM
DiSbaDbOi
Oct 28, 2003 10:41 PM
MeanGreenEG9
Mar 21, 2003 06:10 PM
jcivic
Feb 11, 2003 07:56 PM
