Frustrated with coolant hose...
Old Apr 22, 2004 | 01:57 PM
BrokenLimits's Avatar
Default Frustrated with coolant hose...
I have a 2000 Civic Si with a Sunk2 Intake Manifold and a Prelude Throttle Body. I replaced the coolant lines for the Prelude throttle body because the stock ones dont line up.
Heres my problem. The coolant hose that runs from the back of the intake into a "U" shape and then back into the block is leaking at the intake manifold. I replaced that hose thinking maybe the hose was just shot but it still leaks.
It almost seems like the reciever on the Skunk2 Manifold for the hose is too small.
I have purchased sealer but I am too dan impatient I guess. I am going to apply some and let the car sit over night but I am not sure this is going to help.
Any suggestions would be most appreciated...
Old Apr 22, 2004 | 02:00 PM
MaxSterling's Avatar
Default Re: Frustrated with coolant hose... (BrokenLimits)
have you tried using worm clamps?
Old Apr 22, 2004 | 02:01 PM
Default Re: Frustrated with coolant hose... (MaxSterling)
why are you using skuck2 manifold, when the one on the si is as good if not better.
Old Apr 22, 2004 | 02:10 PM
uhh are you joking? The Si stock intake manifold is a hell of a lot more restrictive then the skunk2.
Yeah I tried a screw style clamp but it sucked...
Old Apr 22, 2004 | 03:05 PM
Well here is what I did for now. I just went outside and put a **** LOAD of Honda bond on the Coolant line inside and where it seals, and then I put a **** LOAD on the recieving fitting.
I am letting them sit for about an hour and then I am going to connect them together and then let that sit over night...
HOPEFULLY that will fix it
Old Apr 22, 2004 | 03:09 PM
eg6beater's Avatar
bond **** dont hold up too well against long term exposure to fluids..esp. hot fluids. if there is enough pressure exerted by the fluid pressure to leak...you will have problems with leakage again.
Old Apr 22, 2004 | 03:43 PM
Default Re: Frustrated with coolant hose... (eg6beater)
well I am using the Coolant resisant bond that is like Honda Bond from Advanced Auto. Its said for High Heat and stuff. I am out of options...
MugenTGZ
May 22, 2013 01:57 AM
90blkteg
May 6, 2008 12:20 PM
gnccracer18
Mar 24, 2008 06:14 PM
kyle-Lst
16
May 8, 2007 10:00 AM
si0385.
Dec 17, 2005 01:59 PM
