DA coolant leak help
Re: DA coolant leak help (JETSPD1477)
Yah theres a couple lines back there, i had a problem with mine but didnt know what it was. later found out it was my effin water pump. that sucked to change. haha
Re: DA coolant leak help (90blkteg)
they're not really under the intake manifold. they're sorta to the side around the thermostat. there's only one that's under the intake manifold. they're all pretty easy to get to from the top. the one that's under you can get from the bottom by the oil filter
Re: DA coolant leak help (super jdm yo)
Thanks I found out which hose it was. It was the hose that goes from the throttle body to the head. It was ripped open as if someone took a bite out of it. Thanks once again.
Nobody123
12-22-2011 05:16 PM
Mr.Chow
06-14-2006 12:39 PM
