Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
I think my ZEX N20 brain took a shit on me, PLEASE HELP ME DIAGNOSE this PLEASE!!! (also some Q's on
Old Apr 22, 2004 | 01:14 PM
CivicSiRracer69's Avatar
Default I think my ZEX N20 brain took a **** on me, PLEASE HELP ME DIAGNOSE this PLEASE!!! (also some Q's on
ok so Ive had this Zex kit for about 2 months now and I think "the brain" took a ****, The purge valve works fine so I know im getting N20 to the Brain, so there is no kinks in the line or anything. When I flip the arming switch my test light goes off when the switch is on, the ground is fine and so is the TPS wire, I took the nozzle out of the intake and had a buddy go full throttle and nothing sprayed out... So Im thinking the internals are fucked up... Anyways anyone ever have the same thing? Also Im doing a small lil build up now, and I was gonna go Direct port aka WET set up... What is all needed to make that work...I allready have the bottle...
So I would need a N20 soleniod a Fuel Soleniod and a micro switch for the throttle right?
Also where does the Feul soleniod pick up gas from? a extra -AN port in the fuel rail??
Anyways thanx and I hope to see some hits on this cause IM LOST!!!
Old Apr 22, 2004 | 01:39 PM
hYbRiD EeEkAy's Avatar
Default Re: I think my ZEX N20 brain took a **** on me, PLEASE HELP ME DIAGNOSE this PLEASE!!! (also some Q'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRracer69 &raquo;</TD></TR><TR><TD CLASS="quote">ok so Ive had this Zex kit for about 2 months now and I think "the brain" took a ****, The purge valve works fine so I know im getting N20 to the Brain, so there is no kinks in the line or anything. When I flip the arming switch my test light goes off when the switch is on, the ground is fine and so is the TPS wire, I took the nozzle out of the intake and had a buddy go full throttle and nothing sprayed out... So Im thinking the internals are fucked up... Anyways anyone ever have the same thing? Also Im doing a small lil build up now, and I was gonna go Direct port aka WET set up... What is all needed to make that work...I allready have the bottle...
Anyways thanx and I hope to see some hits on this cause IM LOST!!! </TD></TR></TABLE>
direct port and wet are 2 different systems
Old Apr 22, 2004 | 01:48 PM
djickabod's Avatar
First off I had the same problem with my Zex brain not sprayin. This is what you need to do.
1. Make sure you have a Constant 12 volt power sorce.
2. I hooked up a direct hot line from the Battery to the Box then I had a friend push the pedal full throttle. And It sprayed. You might have a lose connection.
I called Zex and they told me to test it with the Hot line before you start thinking it is your box ****'n on you.
Good luck!
Old Jul 19, 2009 | 07:55 AM
jason0595's Avatar
good luck to you!
projectDB7
May 18, 2015 11:05 PM
lCHaCHeel
Jul 24, 2006 05:46 PM
untitled
Sep 30, 2004 01:57 PM
jisecup
Jul 17, 2003 11:29 PM
DUCK COMMANDER
Jan 14, 2003 06:26 PM
