Injector Resistor Box wiring help...
From: In the heart of the ghetto of the, Suburbs NYC
OK, from the help Thread for the H22, i got that you should cut the 4 same wire color from the civic harness anf connect them to the 4 black wires on the resistor box? Correct so far?
So my question is, where do i connect the red red wire (any power wire)...also what about the wires that were cut..what do i do with those...
Is this all that i need to do for the resistor box...HELP
the cut u made on those 4 wires, well the four ends that go to the injectors goes to each individual black wire. The one red wire gets sodered in with the other 4 wires going to the ECU that u just cut. yes thats right all four ends, and the one red wire all together.
thx man
That's what i was confused about...the one red wire must attach to all 4 wires that was cut...great
the four wires for the injectors go to the four black wires
the red wire is the wire out
so you are going from one wire to four (in a sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">the four wires for the injectors go to the four black wires
so you are going from one wire to four (in a sense)</TD></TR></TABLE>
Does it matter if it's the other way around? I mean, it's a resistor anyway (not a diode or complicated circuit) right?
CPreston
Feb 11, 2011 02:38 PM
