Turbo bogg help!
setup: 00 gsr built block with rod piston (9:8) and block guard....drag gen 3 turbo kit 310 injectors....vfac
i got the missing link...using check valves...no leeks thru the map sensor....boggs out at 4k when you floor it.
Wait wait...you're confusing me a bit here.
You're using larger injectors...fine
Now, you say you are using a missing link AND check valves. Lost me there.
I am also not sure if you are running an FMU or what. If you are not running an FMU and you are just running an AFC non hack style with some 310s, I think you found your problem, LOL.
hybridb18
Apr 21, 2003 10:46 AM
