Turbo bogg help!
Old Apr 21, 2004 | 08:13 PM
b00sted_GS-R's Avatar
Default Turbo bogg help!
setup: 00 gsr built block with rod piston (9:8) and block guard....drag gen 3 turbo kit 310 injectors....vfac
i got the missing link...using check valves...no leeks thru the map sensor....boggs out at 4k when you floor it.
Old Apr 21, 2004 | 08:15 PM
boosted_dc2's Avatar
Default Re: Turbo bogg help! (b00sted_GS-R)
get it tuned, if your running the fmu then your probably running rich as hell.
Landon
Old Apr 21, 2004 | 08:32 PM
Freeltec's Avatar
put spark plug gap tp .025 it will fix
Old Apr 22, 2004 | 05:27 PM
pollito's Avatar
Wait wait...you're confusing me a bit here.
You're using larger injectors...fine
Now, you say you are using a missing link AND check valves. Lost me there.
I am also not sure if you are running an FMU or what. If you are not running an FMU and you are just running an AFC non hack style with some 310s, I think you found your problem, LOL.
wiz321654
Oct 31, 2005 07:23 AM
steelies
Nov 7, 2004 10:52 AM
hybridb18
Apr 21, 2003 10:46 AM
queez
Mar 8, 2003 10:22 AM
tyrant
May 27, 2002 08:53 PM
