jdm d15b problem?
hey guys
motor is in etc etc...
few problems im having
engine light is on
and sometimes the car idles at 1500 and it seems like its needing more gas to it..
could it be the ecu that i need to buy??
engine light is on
first off i would check the cel code. this can be done by jumping the 2 pin connector on the pass. side of the drivers compartment, underneath the glove box. shut the car off, put a wire in there,then turn the car back on but dont start it, and count the blinks. the first set of blinks will be long, thats the first #, secong will be short. so a code 23 will be 2 long and three short. then use the codes at the very top of this forum to reference the code, and go from there
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">first off i would check the cel code. this can be done by jumping the 2 pin connector on the pass. side of the drivers compartment, underneath the glove box. shut the car off, put a wire in there,then turn the car back on but dont start it, and count the blinks. the first set of blinks will be long, thats the first #, secong will be short. so a code 23 will be 2 long and three short. then use the codes at the very top of this forum to reference the code, and go from there</TD></TR></TABLE> If the code is less than 10 it will only be fast blinks, just to expand on your post...
What ECU are you running? How many wire O2 sensor? And did you wire up the vtec?
Also try switching up, if remember right, TPS and MAP plugs because both of those sensors got the same plugs.
im running from d15b7 motor
i swapped it in
all plug and play
now i think my starter died!! it takes so long to start up
then i start it up and u hear it like revin high it revs at 1500
i think its the ecu tho?
i swapped it in
all plug and play
it works
im using stock ecu from d15b7 5 SPEED
but its lagging
also i noticed when i go into second at high rpm it grinds 2nd gear
before it never did.....hmm
but this motor came with a clutch too so it could be that..
but its lagging
oh I forgot that d15b7 has p06 ecu. My friend is running that on his d15b but it's chipped for ZEX cam.
Did you try switching MAP, and TPS plugs? It makes the car hesitate when you step on the gas.
