GSR water pump on B18B1 .. [did a search already]....
Old Apr 21, 2004 | 12:02 PM
TRE_'s Avatar
Default GSR water pump on B18B1 .. [did a search already]....
First of all, is it possible to put a 99 GSR waterpump on a b18b1 block? If so, what waterpump gasket do i order for it? GSR gasket or LS gasket... or are they the same?
thanks in advance for any help.
Old Apr 21, 2004 | 12:28 PM
IN VTEC's Avatar
Default Re: GSR water pump on B18B1 .. [did a search already].... (THE_HX)
Use a P72 water pump and timing belt.
Old Apr 21, 2004 | 12:30 PM
Dan GSR's Avatar
Default Re: GSR water pump on B18B1 .. [did a search already].... (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Use a P72 water pump and timing belt.</TD></TR></TABLE>
GSR timing belt must be used when changing to GSR water pump
Old Apr 21, 2004 | 12:35 PM
1bad-eg's Avatar
I know for a fact that if you buy the waterpump through an acura dealer, the pump comes with the gasket all ready.
Old Apr 21, 2004 | 12:41 PM
TRE_'s Avatar
Default Re: GSR water pump on B18B1 .. [did a search already].... (1bad-eg)
awesome, thanks for the replies guys... i was already planning on using the gsr timing belt too... GSR waterpump gasket right?
btw, i already have the pump, i just need a new gasket.
Old Apr 21, 2004 | 12:43 PM
IN VTEC's Avatar
The gaskets are probably the same regardless, but if by chance they aren't, then you should get the one for a GS-R.
Old Apr 21, 2004 | 03:06 PM
TRE_'s Avatar
thanks for the info everyone!
Old Apr 21, 2004 | 03:57 PM
arw321's Avatar
The gaskets should be the same, the only difference between the pumps are the number of teeth on the impeller gear.
b20steveo
May 3, 2009 08:51 PM
hondmywrld
Aug 29, 2007 11:14 PM
TooManyTickets
14
May 27, 2007 03:05 PM
rafiq7
Apr 15, 2005 03:44 PM
DougNuts
Apr 1, 2005 05:26 AM
