My car won't start, i've tried almost everything.
Old Apr 21, 2004 | 11:40 AM
bub838's Avatar
Default My car won't start, i've tried almost everything.
Ok, im just gonna make one post for everything so far.
cap/rotor replaced - nothing
ignition coil replaced = nothing
ICM replaced = nothing
Main relay replaced = nothing
jump from another car = nothing
checked fuses = nothing
Notes:
1/4 tank left
radio still works fine
ra ra ra ra ra sound...still comming
NO SPARK I'am still not getting a spark even after replaceing things.
could it be the whole distributor? when i compared my distributor and bob's distributor...there was rust colored build up on the metal shaft in my dizzy, but none on his.
Should I try to switch the shafts? can switch dizzys outright, obd1 obd2 etc.
also, is it right for the main relay to make a ticking sound when i try to start the car up? it tics when i hold the key in the third position...
could it be fuel delivery?
could it be the starter?
i thought itd be electrical because of no spark.
i might just have to take it in
Old Apr 21, 2004 | 12:22 PM
Audi A4's Avatar
Default Re: My car won't start, i've tried almost everything. (bub838)
could be the dizzy, or the ecm... which u should pray it isnt that... maybe alternator? starter? changed plugs and wires? are u sure u have gas... just some suggestions
Old Apr 21, 2004 | 12:54 PM
projectTeG's Avatar
try the ignitor
Old Apr 21, 2004 | 01:09 PM
Boofster's Avatar
Default Re: (projectTeG)
He said he replaced the ignitor (ICM - Ignition Control Module).
Did you hit a hard bump? Is there red dust inside your dizzy? Mine did the same, turned over but no spark.
Either way, it's probably the main assembly. (Part # 4)
Should be able to find a new one for $100.
Old Apr 21, 2004 | 01:18 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
I'm assuming the "ra ra ra" is not the chant of the crowd, but rather your engine trying to turn over. You can rule out the battery and probably starter. If your getting no spark you probably need a distributor.
Did the car die on you while you were driving or did it just not start one day?
I had to replace my distributor last year. Got it from a yard online for about $125. - http://www.car-part.com/
Get a new cap & rotor. Then plugs and wires if it's been a while.
Old Apr 21, 2004 | 01:28 PM
Audi A4's Avatar
Default Re: My car won't start, i've tried almost everything. (Tim2179)
i know this sounds dumb but also check the firing order... make sure the plug wires are in right order
Old Apr 21, 2004 | 01:35 PM
Anthrax-VX's Avatar
Default Re: My car won't start, i've tried almost everything. (DRAG lll INTEGRA)
it can be you have no fuel delivery. fuel pump not workin. fuel filter clogged. if its turning over its not the starter. .. recomend check fuel flow and if that doesnt do it get a new dizzy.
Old Apr 21, 2004 | 04:38 PM
bub838's Avatar
Default Re: (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">He said he replaced the ignitor (ICM - Ignition Control Module).
Should be able to find a new one for $100.</TD></TR></TABLE>
yes! yes! red dust! i knew that **** couldnt be good!
i have a spare obd2 dizzy laying around, can i just swap all the **** inside of it (basically everything short of the harness, which doesnt fit) ?
Old Apr 21, 2004 | 06:13 PM
Audi A4's Avatar
Default Re: (bub838)
yes u can
Old Apr 21, 2004 | 06:45 PM
maxxdout's Avatar
Default Re: (DRAG lll INTEGRA)
3 things needed for any engine: fuel, spartk, timing.
With those 3 you get something.
check spark, pull a wire, use a timing light, something.
fuel, can you hear the pump prime in the ON position? does it smell like gas if you pull a plug??
timing, a timing light helps.
See if yo ugot all this stuff, remember, check the simple first stuff!!
goo luck
Old Apr 21, 2004 | 07:02 PM
bub838's Avatar
see, whats the sound the pump makes, people have told me to do this already, but i dont know what to listen for, because i never paid attention to it before.
Old Apr 21, 2004 | 07:39 PM
m R g S r's Avatar
Check the compression also. I know it has nothing to do wiht the spark, but it could be the cause of it not starting. Are you touching the base of the plug to something metal when you test for a spark? If you just hold it in the air it will not spark.
Old Apr 21, 2004 | 08:35 PM
bub838's Avatar
i stuck a wire up there and touched it to metal
90_Si
31
Oct 5, 2019 07:42 AM
dsettlemoir
May 7, 2016 03:34 AM
JASIYAH6
May 28, 2009 10:10 AM
90crxdxb16
Nov 17, 2006 03:54 PM
TizmPizm
Aug 5, 2006 05:14 PM
