tips for valve adjustment
Old Oct 30, 2001 | 03:58 PM
D-SPEED's Avatar
Default tips for valve adjustment
me and my bro did a valve adjustment on his LS the other day for the first time. We got it done correctly, but it took awhile. Every time we would think that the drag on the feeler was within spec, it was either tight or loose when we locked the nut. We did understand that weight on the valve tool will put weight on the feeler gauge, as we tried to account for that. We really tried to hold the tool steady while locking the nut also.
any tips for doing it correctly/efficiently ?
we are about to do my gizzer and were hoping to get it done a little quicker
thanks
Old Oct 30, 2001 | 04:12 PM
rioninja's Avatar
Default Re: tips for valve adjustment (D-SPEED)
Do it after the car has been sitting overnight. (which goes without saying, since it should be completly cold anyhow). You'll get a better feel for drag if most of the oil has gotten a chance to drain off the parts. Also do your best to keep the feeler gauge at a straight angle.
Old Oct 30, 2001 | 05:56 PM
BluePrintmfg.com's Avatar
Banned
sounds like you guys are doing it right, but seems to me you guys are having a problem with the valve adjustments, Snap-on and other big name tool companies carry a valve adjustment tool. IT save alot of time and lets you do it the proper way.
Old Oct 30, 2001 | 06:04 PM
fixhondas's Avatar
It is better in my opinion (valvetrain wise- not performance) to have clearance a little loose opposed to too tight. I do recommend getting the jam nut tool and some long, flat (not angled) feeler guages. The engine must be 100 degrees or cooler. Practice makes perfect.
Old Oct 30, 2001 | 09:19 PM
Phat Corolla's Avatar
New User
Default Re: tips for valve adjustment (fixhondas)
The snap-on tool is amazing. I bought it a while ago and it was worth the 45 bucks.
Old Oct 30, 2001 | 09:26 PM
Blown90hatcH's Avatar
Who had that Snap-on part number for a GSR valve adjustment tool? I need to swoop one ASAP!!!
Thanks
Old Oct 30, 2001 | 10:21 PM
New User
Default Re: tips for valve adjustment (Blown90hatcH)
It's on the snap-on site i think. just get the 10mm one. they're universal. I bought mine off of a snap-on truck.
Old Oct 31, 2001 | 06:35 AM
betsuni's Avatar
snap on part# YA8895 , make sure you get the 10mm
Old Oct 31, 2001 | 04:11 PM
fixhondas's Avatar
Default Re: tips for valve adjustment (betsuni)
the non vtec DOHC motors use 12mm jam nuts
D-SPEED's Avatar
yeah i have the snap on tool.
if you go to the snap-on site to order the item, they had a misprint mixing up 10mm and 12mm jam bolts. the above part # is correct
i guess i just need some more practice
Old Oct 31, 2001 | 05:05 PM
Thanks...Ordered it today.
numotive
Oct 6, 2016 06:57 PM
civicsaremean
Jun 18, 2007 07:32 PM
boostincoupe
24
Oct 30, 2006 06:43 PM
_Endless_
Jul 7, 2004 06:24 AM
fe519
Mar 22, 2003 08:53 AM
