mini me swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87hondacivic »</TD></TR><TR><TD CLASS="quote">is it possible to do a mini me swap if you have a ew3 engine</TD></TR></TABLE>
What in the **** is a EW3 engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdanglez »</TD></TR><TR><TD CLASS="quote">mini me swap
in which way is it
exactly?
</TD></TR></TABLE>in which way is it
exactly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham »</TD></TR><TR><TD CLASS="quote">
in which way is it
exactly?</TD></TR></TABLE>
Talk to BauleyCivic. Ask him if he'd do it all over.
in which way is it
exactly?</TD></TR></TABLE>Talk to BauleyCivic. Ask him if he'd do it all over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Talk to BauleyCivic. Ask him if he'd do it all over. </TD></TR></TABLE>
He has to be the coolest guy
his write up inspired me to do my mini me swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">mini me
whooo hooo baby. wat is a EW3</TD></TR></TABLE>.
Beats the living **** out of me
whooo hooo baby. wat is a EW3</TD></TR></TABLE>.Beats the living **** out of me
That is what the honda dealership told me i had today. i didn't know exactly what the f*** they were talking about either. my car is a 87 civic si (hb). it has a 1.5L with pgm-fi. my timing belt broke and the cheapest i can get the valves fixed and head machined is like $300 so i figured i might as well do a mini me swap but i can't figure out which motor i have
your engine is an EW3, thats the engine code (as in D16A6, B16A2, etc..). no, a mini-me would be hard as hell on your engine, basically because it's pre-88. in 88 they went to all d-series engines, and you can find an ecu to work, so you could do it. they are easiest to do on 92+ cars.
your best bet will be to find an engine from a junkyard, and hope it works. you should be able to find one for around $150 tops
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87hondacivic »</TD></TR><TR><TD CLASS="quote">im use to the rx-7 engines</TD></TR></TABLE>
gosh, i'm sorry....
gosh, i'm sorry....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">
gosh, i'm sorry....
oooohhhh boy, dont start a flame war about pistons vs rotaries man
you'll burn at the stake for that sorta thing!
gosh, i'm sorry....
</TD></TR></TABLE>oooohhhh boy, dont start a flame war about pistons vs rotaries man
well i like the honda's better and i just gave up on my rx7 but for right now i have to get my honda fixed but i heard it has the lighter of the body's that honda makes im not sure if thats true or not but what would be the best engine setup
yeah, i just don't play with mr wankel
anyways, the easiest peppy swap would be a D16A1 out of an 88-89 integra (1.6L DOHC non-vtec, similar to the JDM DOHC ZC engine). all wheel disc brakes will also swap over from that car. a friend of mine bought an 85 crx for $75, bought an 89 teg for $50, swapped over all wiring from headlight to taillight, all brakes/suspension, seats, and the engine/tranny/ecu. everything bolts right in. he had less than $200 in one of the funnest little hellraisers i've ever ridden in
look for a really good deal on a wrecked 86-89 integra. the 88-89 is better because the engine has a little higher compression.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">your engine is an EW3, thats the engine code (as in D16A6, B16A2, etc..). no, a mini-me would be hard as hell on your engine, basically because it's pre-88. in 88 they went to all d-series engines, and you can find an ecu to work, so you could do it. they are easiest to do on 92+ cars.
exmaple of real knowledge on honda-tech.
you can easier find d16z6 complete swap on here used for 4 or 5 bills. good luck!
rodimus
Oct 31, 2006 02:53 PM
