Need help put turbo on now car smokes
I hav e ad16z6 with 160k on it . I put a T25 turbo on it and now it smokes when i start it up till it gets warm. Then it blows a little when i get on it hard. Its white smoke but it almost smells like gas. What do u think it could me
IF the turbo was new, then there is a good chance its something in your motor. Anything from oil (which is realy blue smoke but can look white) it could be rings, a cracked piston, cracked head, head gasket the list goes on. If the turbo was new I would suggest doing a leak down test to find the cause of your smoke.
IF the turbo was used. Then that is probably the cause problem, especialy if the turbo was from a junk yard and sat for a long time.
VTgringo
Jul 1, 2003 06:44 PM
