Need help put turbo on now car smokes
I hav e ad16z6 with 160k on it . I put a T25 turbo on it and now it smokes when i start it up till it gets warm. Then it blows a little when i get on it hard. Its white smoke but it almost smells like gas. What do u think it could me
Re: Need help put turbo on now car smokes (91glassycrx)
is the smoke coming from the motor??
does it smell like gas or more like pancake syrup ?
was it a used turbo ? |
You need to give us more info..
Did u leave the Stock pistons? Is the turbo used? Did it smoked prior to the turbo install? Could be a lot of factors but u need to give us the info. |
Re: (fjt)
Search. The "why does my car smoke?" question is asked here a few times a week. https://honda-tech.com/forums/images/smilies/emthup.gif
IF the turbo was new, then there is a good chance its something in your motor. Anything from oil (which is realy blue smoke but can look white) it could be rings, a cracked piston, cracked head, head gasket the list goes on. If the turbo was new I would suggest doing a leak down test to find the cause of your smoke.
IF the turbo was used. Then that is probably the cause problem, especialy if the turbo was from a junk yard and sat for a long time. |
