Greddy Prof B Not working
Old Apr 17, 2004 | 08:22 AM
Quad-Damag's Avatar
Default Greddy Prof B Not working
Ok, i checked all the lines, when i take off the vaccume from the boost controler it's working great, u can feel and hear it, strong vac, it's all working, I havn't done anything, i just changed the battery, and now they car won't go over 5 psi, i use to be runing 8 to 10 psi with the prof b, now im runing 5 and its so slow.
I don't have a leak in my charge pipes, checked everything, the turbo is working great. I checked the wiring for the Prof b looks ok, everything hooked up, works like its working great. My boost guage is only reading 5 to 6 psi and it feels like that, so i don't think it's my gauge.
Few things i was thinking it might be, wastegate?
cloged CAT? I have a 2.5 inch high flow, heard it can effect boost
Prof b is broken, or had a short
any input?
Old Apr 17, 2004 | 10:08 AM
Cruiser G's Avatar
Default Re: Greddy Prof B Not working (Quad-Damge)
Im having a similar problem with mine but its kinda opposite, it wont hold any boost at all. If i just let it go the boost will keep rising even though all of the **** settings are set to their lowest. Even when the controller is off it does the same thing, its wierd cause it was working fine to begin with, bump for you!
Old Apr 17, 2004 | 10:31 AM
accordfreak's Avatar
does the solenoid leak like mine did? greddy
https://honda-tech.com/zerothread?id=782447
Old Apr 17, 2004 | 09:25 PM
Trikz's Avatar
go hks evc 5 it works nice.
Old Apr 17, 2004 | 11:41 PM
fab-forum.com's Avatar
Default Re: Greddy Prof B Not working (Trikz)
yeah, mines a joke, cannot figure out that $300 piece of crap. Does anyone know how the hell you are supposed to set it up?
Old Apr 17, 2004 | 11:44 PM
Quad-Damag's Avatar
Default Re: Greddy Prof B Not working (fab-forum.com)
mine is a prof b spec 1 not the 2, the 2 is crap i have been told
Old Apr 18, 2004 | 01:13 PM
Quad-Damag's Avatar
bumps ?? anyone?
Old Apr 19, 2004 | 09:55 AM
Quad-Damag's Avatar
anyone??????
Old Apr 19, 2004 | 09:58 AM
Nextelbuddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fab-forum.com &raquo;</TD></TR><TR><TD CLASS="quote">yeah, mines a joke, cannot figure out that $300 piece of crap. Does anyone know how the hell you are supposed to set it up?</TD></TR></TABLE>
haha they arent a joke just really complicated at first. i figured out mine with help to HELLA JDM and others on here that had the same problem. read this :
if you have a 5.5 psi spring then the max you can boost is found out by this:
5.5 psi x 2 = 11psi take half of that which is 5.5 and add it to 11 psi which = 16.5 psi.
so the max you can boost is 16.5 psi that is your wastegate springs limit for full boost.
so on this greddy profec b the first setting is changed just by turning the ****. the range is from 0-100 percent. this can be interpreted as a percent of yout max boost which is 16.5 psi ok? so say you want to boost 10 psi for example.... you need to calculate what percent of 16.5 = 10 psi. so if 0 % = 0 psi then that means 100 % = 16.5 psi right? so if you want to boost 10 psi then you need to find out what percent of 16.5 psi = 10 psi......
so we discover that 61 % of 16.5 psi = 10.065 psi thats close enough.
set your SET boost ( turn the ****) to 61%
leave the gain @ 10 for now (play with that later to help if it spikes)
now the 3rd setting SETBOOST (setting right after GAIN) this is read in PSI. so if is displays 103 you can interpret that as 10.3 psi ok? and you want this setting set as close to your very first setting of 61 % which is also known as 10 psi.
so since your first setting is @ 61% AKA 10 PSI then you would probably want to have your 3rd setting SETBOOST set @ 90 or AKA 9.0 psi.
hope that helps and remember that this is for a wastegate spring of 5.5 psi
if yo have a different size wastegate spring find out the MAX limit by using the procedure mentioned first above in my post and then figure out everything else accordingly
Old Apr 19, 2004 | 10:17 AM
PM-Performance's Avatar
Default Re: Greddy Prof B Not working (NextelBuddy)
Mine always seemed to work fine. its jsut getting used to the set up
Old Apr 19, 2004 | 10:26 AM
Vtec92Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy &raquo;</TD></TR><TR><TD CLASS="quote">
nice explanation on the profec b
Old Apr 19, 2004 | 11:32 AM
Quad-Damag's Avatar
Default Re: Greddy Prof B Not working (Vtec92Civic)
2 bad im using the one with **** not the digital one anyone?
Old Apr 19, 2004 | 07:23 PM
Quad-Damag's Avatar
all wires are hookedup great, there is vacuume from the boost line to the sender any idea? It looks like it working but it's not
Old Apr 19, 2004 | 07:31 PM
turbosi03's Avatar
yeah mine doesn't work either...? but my problem is also the boost keeps going up even with all the setting low...
how can you check to see if the cylinoid is leaking?
Old Apr 19, 2004 | 07:37 PM
MaxBoostC1's Avatar
did u change the dip switches in the back of the head unit...internal / external wastegate setup???
Old Apr 19, 2004 | 08:18 PM
stephenB!'s Avatar
Default Re: Greddy Prof B Not working (B18c--tEK)
this is Hella_JDM , ya nextel hooked it up with the logic , its real easy . anyway alex your spec 1 is an antique piece of **** . solenoid is prolly bad dood.
Old Apr 19, 2004 | 08:44 PM
Quad-Damag's Avatar
Default Re: Greddy Prof B Not working (TURbb1)
Ya i hope it's not any way to check it, no leaks, I am sure no leaks at all.
Old Apr 21, 2004 | 11:41 AM
Quad-Damag's Avatar
tuned out to be, i had the wires along the charge pipe and it moving striped the wires, i just re solder the wires and moved it, so the charge pipe isn't touching
Runing cool as ****, thanks for the help all
Old Apr 21, 2004 | 12:49 PM
turbo*s2k's Avatar
Here we go again. Nextel buddy explained it good for the Profec b-spec. I hope you get yours figured out.
tyoung
Jul 18, 2008 02:06 AM
turbotime
Aug 19, 2006 09:54 PM
99lspwr
Mar 18, 2004 02:07 PM
93TurboSi
Oct 16, 2003 06:04 PM
