DECK PROBLEM!!!! No Sound..........
Old Apr 20, 2004 | 03:02 PM
07's Avatar
07
Default DECK PROBLEM!!!! No Sound..........
OK. I know my way around Hondas very well.
- I bought a older Kenwood x815 excelon. Made up a wire harness using the kenwood harness and connector to the stock radio plug. good connections, shrinkwrapped and all.
Put in the x815. Works normal EXCEPT I have absolutely NO sound coming out of the speakers. Tried adjusting the settings. But nothing helped.
I then used that same harness I just made and plugged it into my OLD kenwood deck (NOT the x815) and it worked perfect.
If the radio does turn out to be junk, Does anyone know there hands around to fixing the problem? schematics or something for this deck?
Thanks!
Old Apr 20, 2004 | 07:06 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: DECK PROBLEM!!!! No Sound.......... (Calculator)
make sure that deck has an internal amplifier... some didnt come with them and just had nice quality 4v pre-amp outputs.
Old Apr 20, 2004 | 09:58 PM
oh KSERIES's Avatar
Bump, I'm having the same damn problem.
Old Apr 21, 2004 | 03:39 AM
07's Avatar
07
Default Re: DECK PROBLEM!!!! No Sound.......... (94HCivic)
it has those preouts. But also says 45x4 on the cover, so i am assuming that would mean it has an internal amp?
Old Apr 21, 2004 | 06:17 AM
Ludeboi's Avatar
did you buy the unit new or used? try checking your wires one more time. if two speaker wires touch, it will short out the internal amp.
Old Apr 21, 2004 | 11:10 AM
oh KSERIES's Avatar
how would you go about fixing that internal amp? would you have to send it out to the company, or is there a way to fix it on your own?
Old Apr 21, 2004 | 07:17 PM
you'd have to send it back to the company... it would be cheaper to just throw on a 4-channel amp, or to just replace the deck...
Old Apr 22, 2004 | 06:53 AM
AndyGCT's Avatar
if youre testing it with the radio, is the antenna connected?
If its with CD itshould work then and there..Another thing is to double check that the speaker connections on your pre-fabd wiring harness are still together? maybe they are hooked up wrong...
Old Apr 22, 2004 | 06:58 AM
spark plugs.
Guest
Posts: n/a
Default Re: DECK PROBLEM!!!! No Sound.......... (AndyGCT)
i say you check the harness, the settings on the deck (make sure that the consarned thing isn't on mute or sumthing), and make sure you didn't fry the deck sum how.
Old Apr 22, 2004 | 02:27 PM
07's Avatar
07
Default Re: DECK PROBLEM!!!! No Sound.......... (troublecodes)
bought it used. previous owner only used it with a amp.
harness is correct. I used the harness i made in my old kenwood and it worked.
antenna was connected, also tried to play a cd. It played but no damn sound, which is the same the antenna is doing.
Old Apr 22, 2004 | 11:49 PM
niccuhles's Avatar
i wrote this up in another tread too...check all of your speakers and speaker wires, it mite be grounding out somewhere(wire or speaker prongs are touchin another source of metal in your car.) and if that still doesnt work one of your speakers mite be blown, the best way to check is to pull the radio out and individually connect a speaker to each pair of speaker wires(purple/purple black, green/green black, etc..) if your still not getting sound then the deck is bad.
Old Apr 23, 2004 | 06:11 PM
jdmotorsports's Avatar
Default Re: (niccuhles)
you people dont read do you? damn.
well it sounds like the internal amp is shot. the person who sold it to you might not of taped off the speakers leads and blew em. it would be cheaper to get a 4channel amp then to have it fixed.
Old Apr 24, 2004 | 10:33 AM
07's Avatar
07
Default Re: (jdmotorsports)
i do read, i repeated my answers a billion times. The people asking questions didnt read.
Old Apr 24, 2004 | 12:16 PM
Default Re: (Calculator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calculator &raquo;</TD></TR><TR><TD CLASS="quote">i do read, i repeated my answers a billion times. The people asking questions didnt read.</TD></TR></TABLE>
i know..i was refering to the people who post the same questions/anwsers that 3 other people posted.
Old Apr 24, 2004 | 08:21 PM
07's Avatar
07
gotcha
sDc5
Audio / Security / Video
Aug 6, 2007 10:37 AM
civicguy92
28
Jun 26, 2007 06:01 PM
94lude_si
Nov 4, 2006 10:41 PM
vinuneuro
Jun 23, 2006 06:24 PM
Cozmo Kraemer
Mar 22, 2003 06:29 PM
