'93 Civic CX HB O2 sensor - to emulate or not??? Or other suggestions...
Old Apr 20, 2004 | 03:02 PM
D_S_2051's Avatar
Default '93 Civic CX HB O2 sensor - to emulate or not??? Or other suggestions...
Ok... this is my first post... My setup is '93 civic cx with '89 DX D15B2 engine... everything else is fairly stock on the car. The O2 sensor went bad and I replaced it with a cheap universal bosch single wire O2. The check engine light still comes on... even after resetting the ECU. I had plenty of power before re-installing the exhaust system... CAT-back... I do have to admit that I removed the CAT Internals to facilitate better flow. I want to eventually run headers on it... but as for the O2 problem... what can i do to eliminate my problems...??? should I run an O2 emulator... or does anyone know of a better solution??? I did learn that the '92 and '93 CX models had a special O2 sensor, which is really expensive... Should i save my money and replace it with the stock sensor, or replace it completely with an emulator???
Old Apr 20, 2004 | 03:24 PM
dantastic's Avatar
Default Re: '93 Civic CX HB O2 sensor - to emulate or not??? Or other suggestions... (D_S_2051)
what ecu are you running? it will determine what 02 sensor you need to run
Old Apr 21, 2004 | 10:19 AM
D_S_2051's Avatar
Default Re: '93 Civic CX HB O2 sensor - to emulate or not??? Or other suggestions... (dantastic)
I am currently running a PO6 ECM (37820-P06-A00). It was replaced last summer when my battery had a little melt down... and fried the ECM... I don't know what the previous ECM was... I do still have it somewhere... if I need it.
Thanks for the help.
Old Apr 21, 2004 | 10:39 AM
DymSum's Avatar
I'm not to sure on the ecu myself so someone more expirienced may wanna answer that one, but a vendor in the performance section has a o2 sim on sale this month for like 25$, hell i gonna pick one up probally cause i got a similiar problem with a ek.
Modified by GrimShortcake at 11:14 AM 4/22/2004
Old Apr 21, 2004 | 01:31 PM
D_S_2051's Avatar
Default Re: (GrimShortcake)
what is the link? I definately want one.... sure beats the hell out of almost $200 for a new 02 sensor...
Thanks for the heads up!!!
Old Apr 21, 2004 | 02:04 PM
D_S_2051's Avatar
Default Re: (D_S_2051)
I did run across a web site that was really educational... It is:
http://www.o2simulator.com/
I also found a link for building your own O2 sim...
http://www.mkiv.com/techarticl...lator/
check it out!!!
Old Apr 22, 2004 | 02:07 AM
DymSum's Avatar
https://honda-tech.com/zerothread?id=836374 theres that link to the vendor selling them in the performance section. He got a link to how ya wire it up and everything also. Doesnt seem to hard.
aDnOhCiViCiS98
Apr 23, 2005 04:46 PM
kun3racer
Jan 23, 2004 05:59 PM
civicracer1993
Mar 20, 2003 10:35 AM
B_1_8_hatch
18
Oct 10, 2002 04:03 PM
