Resetting ECU after Mods?
After installing a header and high-flow cat is it necessary to reset the ECU? If it is, can somebody explain how to do this please...
I have heard that letting the car idle for 10-15 minutes with the new mods would be enough. Is this a myth?
Actaully, you can reset the ECU by pulling the Hazard fuse from the engine bay (instead of disconnecting the battery).
Check out the Helms Manual for the circuit wiring...
And you will need your radio code as mentioned previously.
-Geo
-Geo
hmmm, I'm the second owner and I have no radio code. Where can I get this?
ken00si
Oct 25, 2006 12:28 PM
