ECU reset & Radio Code Question
Old Nov 30, 2003 | 08:52 PM
drive4aliving's Avatar
Modified by drive4aliving at 12:05 AM 1/24/2007
Old Nov 30, 2003 | 11:37 PM
iH8RICERZ's Avatar
Default Re: ECU reset & Radio Code Question (drive4aliving)
not sure about the code, but you can reset the ecu buy either unplugging the battery for 10-15 minutes...and/or pulling the ecu fuse out....but i would definately check to see what the radio code is before you undo the battery
Old Dec 1, 2003 | 02:54 AM
SPOOLINVTEC
Guest
Posts: n/a
the radio code is a 5 digit number.. im willing to guess that the # you have is right. and as far as reseting the codes on the ecu... you have to hook up a diagnostic. i bought one for $200.. to have then all you have to hook it up and scan your system. then you can reset any codes your throwing just my $0.02
Old Dec 1, 2003 | 07:11 AM
mike5809's Avatar
Default Re: ECU reset & Radio Code Question (spoolinvtec)
if u go to the honda dealer with the radio or the serial number on the radio and proof of ownership of car (title, registration, etc) then can look the code up for you.
but i would guess that 5 digit number is it.
Old Dec 1, 2003 | 07:15 AM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinvtec &raquo;</TD></TR><TR><TD CLASS="quote">the radio code is a 5 digit number.. im willing to guess that the # you have is right. and as far as reseting the codes on the ecu... you have to hook up a diagnostic. i bought one for $200.. to have then all you have to hook it up and scan your system. then you can reset any codes your throwing just my $0.02</TD></TR></TABLE>
he's not trying to reset any codes (doesn't have a CEL), so just pull the ECU fuse for 10 minutes or so.....as far as the radio code goes, it is a five digit number so that might be the right one.....only one way to find out
Old Dec 1, 2003 | 08:26 AM
SlalomHonda's Avatar
Yeah that looks like the radio code. Both Tegs I've owned had the sticker on the underside of the front ashtray, pull it out and check...
Old Dec 1, 2003 | 09:35 AM
GSR x13's Avatar
i think its the blue fuse number 15
Old Dec 1, 2003 | 11:01 AM
Top left of the engine fuse box, I usually pull both the 15 and 7.5 fuse...don't have the diagram in front of me.
EFSiR
Acura TL, RL & ZDX
Mar 19, 2008 01:59 PM
thunderboy
Honda Civic (2006 - 2015)
Nov 5, 2007 07:02 PM
GSRnold
Jun 14, 2006 10:27 PM
maximedx
Jan 18, 2004 11:45 AM
drive4aliving
Dec 1, 2003 06:46 AM
