F22B Rods/Pistons
Old Apr 20, 2004 | 05:24 AM
elektrahn's Avatar
Default F22B Rods/Pistons
For the engine builders:
Do h23 aftermarket rods *actually* work in an f22b? If so/not, who makes decent rods besides crower for the F22b?
Also, who makes some decent pistons for the f22b?
Thanks
Old Apr 20, 2004 | 05:43 AM
lingerbw's Avatar
Default Re: F22B Rods/Pistons (elektrahn)
I'm about to install 11:1 Wiseco pistons from raceeng.com. They aren't installed yet, but I just thought I'd give you a starting point. I'm going with my stock rods on this build. Are your plans turbo or N/A?
Old Apr 20, 2004 | 05:50 AM
elektrahn's Avatar
Default Re: F22B Rods/Pistons (lingerbw)
Thank you for the reply. This is for a turbo build.
Old Apr 20, 2004 | 07:11 AM
ForceThis!'s Avatar
all kinds of ppl make pistons for the F/b, just google your engine plus the part you need. as far as 11:1 . . uh, unless you plan some uber engine management, 11:1 for FI is a poor starting point, especially since the stock comp on the F/b is 8.5:1. If turbo is your plan, you may even bump it down some. I have 9.5:1 in my f from CP. ultimately, you budget will determine the product you get. Eagle makes rods for the F too, but the bottom line is you can make virtually anything fit with the proper machining.
Old Apr 20, 2004 | 09:35 AM
lingerbw's Avatar
Default Re: F22B Rods/Pistons (ForceThis!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceThis! &raquo;</TD></TR><TR><TD CLASS="quote"> as far as 11:1 . . uh, unless you plan some uber engine management, 11:1 for FI is a poor starting point, </TD></TR></TABLE>
I agree. I'm staying n/a.
Old Apr 20, 2004 | 09:56 AM
4genaccordfreak's Avatar
Arias also makes some pistons.. although u know that f22;s have a low compression # stock.. so.. just be sure not to lower that # too much.. cuz then it will be overkill..
Old Apr 20, 2004 | 10:51 AM
ForceThis!'s Avatar
Default Re: (4genaccordfreak)
true dat, I was thinking 8.0:1 at the lowest, but even with 9.5:1 at 10#, a vortech unit (1:8, 1:10, 1:12) and 255lph pump is really ok. at the beginning of the whole process on my car I ran the vortech with the stock pump and no other real mods for a while and was totally fine (93octane always) so it's not as touchy as some might have you believe, but I don't have to worry about corn gas or other modifiers.
Old Apr 20, 2004 | 01:44 PM
elektrahn's Avatar
Thank you for the replies guys, but we strayed off the topic somewhat.
Just looking for manufacturers of aftermarket pistons and rods.
Thanks!
Vagitarian
Sep 14, 2012 02:14 PM
khaledbuiltEF
Sep 25, 2010 09:35 PM
willyb92
19
Jun 4, 2010 06:27 PM
OneBanzai
Jul 23, 2009 10:31 PM
