Timing belt tension....
Old Apr 19, 2004 | 05:55 PM
eghatchproject's Avatar
Default Timing belt tension....
Guys, I rotated the crank until the white mark on the pulley was lined up with the mark on the timing cover and the piston in the #1 cylinder was at TDC. My cam timing appears to be on point. So I put everything back together and start the car. There is a noise coming from the side of the block near the timing belt. Could the timing belt be too tight? I noticed quite a difference in the way it accelerates too. I think the belt tension wasnt tight enough before but now it may be too tight?
delsolboi
Mar 13, 2013 11:57 AM
thenext
Oct 28, 2011 06:06 AM
chromeBuddha
Aug 4, 2008 12:43 PM
PrecisionH23a
Aug 14, 2002 09:22 AM
PrecisionH23a
Aug 14, 2002 05:16 AM
