Spark plug wires
Ok i am thinking of buying a set of nology wires and there coil i have a 1999 Civic SI just wanted to know what people though i was also talking to some one about wires and they said that you don't need to waste your money on wires your stock wires are fine and also said that the only time you need to change your wires is if your missfireing. is this true just want a second opion
thanks very much.
thanks very much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic 2ner »</TD></TR><TR><TD CLASS="quote">I dont like to use periods I just keep talking until I run out of breath and die and then right at the last second just moments before I die I slip out another question about something that I could just search for and then finaly I use a period.
when you need to change them use OEM or NGK. From what I've read from SEARCHING OEM's give you the best output. I know someone did a write-up on the gains and losses of HP with 15 y/o OEM plugs against new NGK's and the OEM ones were better.
There are lots of posts about spark plug wires on this forum.
I just researched the subject myself a few weeks ago. OEM are just fine for your car - another popular one is NGK blue...
I however went with MSD wires - saw a good deal on them and went for it...
I dont think that the Nology wires are worth it, and from what I have heard they dont last long...
