Timiong Belt Replacement...H22
Old Apr 19, 2004 | 04:58 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
Default Timiong Belt Replacement (Help)...H22
OK, the motor is out of the car, but how do you get the tension from the timing belt off. I got the balancer shaft belt tensioner loose and that belt off...What i did with the timing belt was slide the belt off by taking out the adjuster, but i know putting the belt on is going to be a bitch. HELP
Also does anyone know if the half shaft for the 95 accord is the same size or same part as the half shaft for the 90-93 Accord? I already have the 95 half shaft, and don't want to spend the 150 for the shaft for the 90-93...(Going with the 89 teg pass. and 90-93 teg driver axle setup)
Lastly. The cam/crank seal should be the only seals I should replace right?
Modified by 92hybridAccord at 10:14 AM 4/19/2004
Old Apr 19, 2004 | 09:41 AM
Adam.'s Avatar
Default Re: Timiong Belt Replacement (Help)...H22 (92hybridAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hybridAccord &raquo;</TD></TR><TR><TD CLASS="quote">OK, the motor is out of the car, but how do you get the tension from the timing belt off. I got the balancer shaft belt tensioner loose and that belt off...What i did with the timing belt was slide the belt off by taking out the adjuster, but i know putting the belt on is going to be a bitch. HELP
Modified by 92hybridAccord at 10:14 AM 4/19/2004</TD></TR></TABLE>
As for the timing belt, there is a part you can buy from honda that allows you to get it working. Basically you remove the screw from the underside of the automatic tensioner, there is an adjusting screw inside there and you turn it so that you can push the tensioner inwards. After that, you take the part that you get from honda, slide it over it to hold it down. Put your timing belt back on the car, then bold on the auto tensioner. Remove the "clamp" that you got from honda and the auto tensioner should auto-tension itself.
Oh, don't forget to put the little screw back on the underside of the auto tensioner before you put it on the car.
Edit, you need part #25 from that drawing.
Old Apr 19, 2004 | 10:29 AM
Default Re: Timiong Belt Replacement (DarkKnight[DMD])
thx man, i figured it had something to do with the tensioner, but i couldn't figure why it would not loosen up a bit. I even went as far as my pry bar..and try to put some pressure onto it..heh
Old Apr 19, 2004 | 10:36 AM
Adam.'s Avatar
Default Re: Timiong Belt Replacement (92hybridAccord)
I have my whole story posted on like the 15th page of the H22/Civic FAQ at the top of this forum.
I think I spent around three hours and ended up making my own tool to get it working correctly. It was a bitch to say the least.
MJDT
Mar 9, 2014 09:17 AM
Murkin_lude
Apr 5, 2012 03:03 PM
SkylineKin
Aug 23, 2009 07:04 PM
kornerk12
Oct 6, 2008 04:55 PM
98hondalude
Sep 24, 2007 10:42 AM
