timing belt 95 lx
timing belt 95 lx
Well my 95 lx has 90k on it and its time for a timing belt. What along with the belt should I be changing as well ?
H-T Order of Merit
Re: timing belt 95 lx (kornerk12)
timing belt
balancer shaft belt
timing belt tensioner (if needed)
balancer shaft belt tensioner (if needed)
water pump
cam seal
front balance shaft seal
crankshaft seal
valve cover gasket
I'm guessing you haven't read through the write-up on this thats linked in the FAQ because this is all covered in that thread. Plus if you search this has been asked before.
balancer shaft belt
water pump
cam seal
crankshaft seal
valve cover gasket
Re: timing belt 95 lx (TouringAccord)
How do I know if they should be replaced ?
H-T Order of Merit
unfortunately you wont know until you take it apart, I just usually replace them anyway to be safe. But if you want to wait until you have it apart just spin the tensioner by hand and feel/listen to the bearing and determine if it needs to be replaced or not. Most that I've come across haven't required replacement but since I usually order everything ahead of time I just order those to make sure I wont have problems.
replace the seals, even the "oil pump" seal. They WILL NOT make it to the second belt change, without leaking oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">timing belt tensioner (if needed)
How do I know if they should be replaced ? </TD></TR></TABLE>
Spin them up, if they sound like a box of rocks, replace them.
If they just sound 'dry' you can carefully pry off the seal, add in a little grease, pop the seal back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">timing belt
balancer shaft belt
water pump
cam seal
crankshaft seal
valve cover gasket
I'm guessing you haven't read through the write-up on this thats linked in the FAQ because this is all covered in that thread. Plus if you search this has been asked before.</TD></TR></TABLE>
When you say tensioner you mean the adjuster, as its called correct ?
And for the front balance shaft seal do I need number 4 or 5 ?
http://www.hondaautomotivepart...=null
And for the crankshaft seal, your refering to the front main seal correct ? Either number 25 or 26 it looks like depending on what brand oil pump ?
balancer shaft belt
water pump
cam seal
crankshaft seal
valve cover gasket
H-T Order of Merit
yes, by tensioner I am referring to the adjuster.
and yes, I am referring to the front main seal which would be #25 iirc.
H-T Order of Merit
I'm not sure but it doesn't sound correct, dimensionally, for the front main seal. I could be wrong as it's been a while...
