schematic (sort of) and step-by-step of tiptronic button shifters
Old Oct 30, 2001 | 03:26 AM
mrlegoman's Avatar
Default schematic (sort of) and step-by-step of tiptronic button shifters
Larger pics are located at
http://www.imagestation.com/album/pi...?id=4292290473
The bottom side of the controller unit :
The up-shift is a white wire with blue stripe and the down-shift is a blue wire with a yellow stripe. The center switch is what activates the sports shifter.
For the button shifter you don't need to worry about taking this unit off.
Between the controller and the wire plug I spliced into the shifter wires
I installed a quick disconnect in the case I needed to remove the buttons. This way I do not have to worry about mending the sliced wires.
I ran the wires under the dash, through the back of the streering wheel and under the SRS system.
A couple zip ties later:
Not to much for looks, but I'll work in fixing that later. First real test run was at the GAP and they worked great!! I was able to shift through the turns without having to remove my grip on the steering wheel!
fun-fun!!!!
[Modified by mrlegoman, 12:28 PM 10/30/2001]
Old Oct 30, 2001 | 06:49 AM
sackdz's Avatar
Default Re: schematic (sort of) and step-by-step of tiptronic button shifters (mrlegoman)
Very cool, nice job documenting
Old Oct 31, 2001 | 09:26 AM
itrhybrid's Avatar
Sweet!
Old Oct 31, 2001 | 01:30 PM
Joe's Avatar
Joe
Default Re: schematic (itrhybrid)
awesome.
Old Oct 31, 2001 | 01:36 PM
SoCal ITR's Avatar
Default Re: schematic (Joe Morris)
TheMuffinMan
Mar 20, 2013 09:55 AM
dstah
Engine Management and Tuning
May 2, 2009 10:13 PM
high_on-rice
Aug 7, 2005 05:22 PM
