i really need help with my turbo civic . please read and give me some ideas of whats wrong
wussup ppl. The problem with my car is that it only goes 5 mph and it does not go quicker than that. for it to move 5 mph i have to take it up to 6500rpm. I changed the oil, i changed the spark plugs. and i still dont know what the problem is . i have 00SI head, 98 ls integra bottom with and si transmission and turbonetics turbo. if anyone cna help me or nees to ask me stuff in order to help me plz im me on my aim at XxKingZofPaki03x. Thank you for your time and cooperation.
~Mohsin
~Mohsin
Dam that could be a dozen things. Did you check your fuel system, sensors, or maybe the oil line that goes from the head to the block (U never know kid). I mean check **** that you wouldn't think had anything to do with your car running like that. is your timing good. Hope it helps.
how well does the motor run. if your hittint 6500 RPMs sounds like a Clutch, or tranny problem
i mean at 6500 u shudl be doing 20+ have u tried any other gears like starting out in 2nd or 3rd?
also when did the problem start? before or after the turbo install? or was everything completed and then one day it just stops working?
we need more information to help u.
I HAD MY TURBO ON FOR 6 MONTHS AND THIS NEVER HAPPENED BEFORE AND ALL OF A SUDDEN 1 DAY I WAS DRIVING I PULLED OVER TO THE SIDE WHEN IT WASNT MOVING AS QUICK AND LOOKED UNDER THE CAR AND WHERE THE TRANSMISSION WAS IT WAS SMOKING A LITTLE BIT . DO YOU THINK THE CLUTCH GOT BURNED OUT? I GOT 290HP@7PSI RIGHT NOW.
XxKingZofPaki03x
Apr 16, 2004 05:53 PM
