Tint removal help!!
Old Apr 16, 2004 | 01:17 PM
s2kds's Avatar
Default Tint removal help!!
I took off my old tint and it left a nasty glue film on my window. What should i use to get it off?
Old Apr 16, 2004 | 01:20 PM
.ShawnD.'s Avatar
soap/warmwater/4 zero guage steelwool/ scrub scrub
Old Apr 16, 2004 | 01:22 PM
iHATEspeedbumps.'s Avatar
Default Re: (.:s h a w n D:.)
theres a product at kragens called "tint off". its an adhesive remover
Old Apr 16, 2004 | 02:25 PM
t-blizzard's Avatar
Default Re: Tint removal help!! (delsol8694)
fully spray the inside of the window with windex, get a big black trash bag and make it 2 pieces, lay the one half on the entire inside of the window, do the same to the other side, let it set out in the sun for like a good 45 mins, then take off the trash bag, and peel a corner of the tint with your finger nail or a razor blade and pull it off, should come right off, use some type of adhesive remove and a rag to get the rest of the remaining adhesive from the tint.
sorry for the clutterness
Old Apr 16, 2004 | 02:44 PM
will7's Avatar
Default Re: Tint removal help!! (t.blizzard)
i take tint off all the time..i use glass cleaner and a razor blade
Old Apr 16, 2004 | 02:45 PM
will7's Avatar
oh and a rag too
Old Apr 16, 2004 | 03:17 PM
jcarothers's Avatar
Default Re: Tint removal help!! (will7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by will7 &raquo;</TD></TR><TR><TD CLASS="quote">i take tint off all the time..i use glass cleaner and a razor blade</TD></TR></TABLE>
that's how my tint came off.
Old Apr 16, 2004 | 03:20 PM
jeremy.'s Avatar
Default Re: Tint removal help!! (jcarothers)
did it come out clean?
that's how my tint came off.</TD></TR></TABLE>
Old Apr 16, 2004 | 03:21 PM
Shaun's Avatar
Default Re: Tint removal help!! (ek_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">did it come out clean?
yup, it did for me, I used the same method
Old Apr 16, 2004 | 03:24 PM
jcarothers's Avatar
yep... very clean. it's time consuming as **** though.
Old Apr 16, 2004 | 03:52 PM
5STAR3's Avatar
i use to work at dealership, and we cleaned all windows with a razor blade.
taking tint off is a biotch
Old Apr 16, 2004 | 04:45 PM
Import13alla's Avatar
Default Re: Tint removal help!! (envision2teg)
concentrated simple green...that stuff works for everything!
Old Apr 16, 2004 | 05:44 PM
NWP4LIFE's Avatar
soapy water and razor blade is all you need. Tint is two layers, the 1st layer rips off clean, but it leaves behind an adhesive. Keep the window wet with the soapy water and just cover every inch with the razor blade. Doesn't take too long, an hour or so for the whole car.
si_motor_spt
15
Aug 17, 2008 05:12 PM
ramos2589
Paint and Body
Jun 23, 2008 04:12 PM
Spicylikcajun
May 20, 2007 08:58 AM
peshte
Jun 8, 2005 07:05 AM
integra15
Aug 9, 2003 12:28 AM
