ecu?
Old Apr 15, 2004 | 12:53 PM
stubk20's Avatar
Default ecu?
just wanted to know if i should get a stock p13 or chipped p13 to throw in on my new motor(h22a4) since i'm just putting it in it will be stock except for an intake. this is the last part i need to complete the swap. anyways just wanted to know if i should spend the extra 10 bucks to get the race ecu. by the way this is my daily driven vehicle.
Old Apr 15, 2004 | 01:05 PM
satan_srv's Avatar
Default Re: ecu? (stub92111)
umm h22a4 uses a P5P ecu, OBDII
Old Apr 15, 2004 | 01:10 PM
stubk20's Avatar
Default Re: ecu? (satan_srv)
the motor came with a harness ob2 to obd1. so i need to get a obd1 ecu and i'm not sure if i should go with a programmed ecu because the motor is stock and the the price difference for the ecus are pretty much the same.
Old Apr 15, 2004 | 01:15 PM
satan_srv's Avatar
you need a p13 and OBDI 345cc injectors, and you should have an injector resistor box
all chipped ecus suck. seriously
GT500FTW
Nov 5, 2012 09:57 AM
jdmborn
Engine Management and Tuning
Jun 20, 2009 08:15 AM
dwarfsinhondas
Apr 7, 2008 11:47 PM
underdog_racer
Nov 11, 2007 08:52 PM
jdmcivicsi7
Jan 13, 2006 09:17 PM
