Anyone know where I can pick up this harness/plug?
Old Apr 15, 2004 | 11:22 AM
Hoosier Daddy's Avatar
Default Anyone know where I can pick up this harness/plug?
Looking for the plug/harness (honestly not sure what it even looks like) for a JDM CRX gauge cluster. I think there are plugs that go in the back. Any info/help would be very much appreciated.
Thanks
Old Apr 15, 2004 | 06:20 PM
Default Re: Anyone know where I can pick up this harness/plug? (Hoosier Daddy)
Anyone?
Old Apr 15, 2004 | 07:05 PM
ThefirstPACT's Avatar
good luck finding them! I looked forever emailed every JDM company with no response and then finally a local shop hooked it up! Good luck!
Old Apr 15, 2004 | 07:06 PM
Davep's Avatar
Just came up with this tonight.
https://honda-tech.com/zerothread?id=811565
Old Apr 15, 2004 | 07:27 PM
Default Re: Anyone know where I can pick up this harness/plug? (Davep)
Thanks a lot man
So basically the middle harness plugs right in.
The left and right right harnesses need to be cut/shaved on each end. Do you remove the pin/wire too?
What is the extra harness plug/harness that needs to be purchased needed for? Sorry, not the greatest at wiring
Old Apr 16, 2004 | 03:52 AM
Davep's Avatar
Yeah, you have to remove the pin from the ends that you shave. The extra plug is the gray one in the pic, the SiR cluster uses 3 main plugs and the USDM cluster only uses 2 main plugs.
Old Apr 16, 2004 | 03:55 AM
Thanks man Is it possible to soldier the last wires into both plugs?
Old Apr 16, 2004 | 04:18 AM
Davep's Avatar
what?
Alex V
Jul 5, 2019 10:46 AM
1nsoman1ac
10
Sep 22, 2009 01:08 PM
asigler
Jul 22, 2009 10:59 AM
nello a.
Dec 24, 2008 12:20 AM
-Gambit-
Sep 8, 2005 10:12 AM
