VTEC wiring in a non-vtec car
Old Oct 29, 2001 | 07:47 AM
Tomakit's Avatar
Default VTEC wiring in a non-vtec car
Note: I already posted this in the hybrid forum, no luck, i've also done a search...
I have a 95 LS-SE, which i just swapped a 98 b18c1 into. Now, the car is currently running on a 95 obd1 ecu (p72), however, the motor
isn't wired to the ecu to run vtec.
I've checked the hybrid site, and have poked around a lot besides that, but i still have some questions.
1) My car's wiring harness doesn't have the vtec wires run to it. Do i just run the wire from the engine to the engine side wiring harness
which plugs into the correct ecu pin? Or do i have to physically run the wire to the engine side wiring harness connector? Or to the ECU
side pin?
for example: I know that Vtec solenoid (yel/grn) has to run to pin A4...can i tap the engine side wire which corresponds to A4, or do I
have to run it to that ecu pin?
Does anyone have any pictures of this done, like which wire ran from where in the engine bay? (Not the pinout diagrams, I have those,
and have a helms)
Also, are there any complications that i might run into while wiring this up?
Tom
Old Oct 29, 2001 | 01:19 PM
3.3.3's Avatar
Default Re: VTEC wiring in a non-vtec car (Tomakit)
you can either tap into the solenoid and run the wires directly into the ECU plug, or run the wires to a vtec controller. either will work.
Old Oct 29, 2001 | 02:42 PM
Katman's Avatar
side pin?
and have a helms)
Tom
...here this pic applies to OBD1 equipped civic & integra's:
Since your car does not have ANY vtec wires, yes you will have to run a wire from the ECU Pin to the VTEC component.
Old Oct 30, 2001 | 04:58 PM
rioninja's Avatar
Default Re: VTEC wiring in a non-vtec car (Katman)
You-da-man, Katman
Old Oct 30, 2001 | 05:31 PM
Katman's Avatar
Default Re: VTEC wiring in a non-vtec car (RioNinja)
...heh thanks..
.....some people can't seem to see that!
Old Nov 5, 2001 | 08:29 AM
Tomakit's Avatar
katman,
got what you said done not too long ago. thanks for the pic.
Tom
Old Nov 5, 2001 | 01:29 PM
Katman's Avatar
word...
96_cvc_b16
13
Mar 21, 2009 08:37 PM
slow_cx
Aug 22, 2007 11:11 AM
northkai3
Jun 5, 2005 10:47 PM
Tomakit
Oct 29, 2001 09:08 AM
Tomakit
Oct 28, 2001 05:37 PM
