Hondata, Safe To Not Let Go Of The Gas While Shifting?
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
are you talking about FTS?
whenever you depress the clutch, if you car is equipped with the clutch switch, the ECU (and not only hondata does that) will drop the RPMs to a set number, it is closely related to FTL (full throttle launch) where the clutch switch works in conjunction with the VSS sensor to keep RPMs at a set number when staging.
stan
stan
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman »</TD></TR><TR><TD CLASS="quote">ask hondata</TD></TR></TABLE>
They had a vid of a guy not letting ago of the gas i think that would blow
just learn how to shift fast. when you can shift fast enough it wont matter if you have the gas on the floor through the shift or not.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman »</TD></TR><TR><TD CLASS="quote">just learn how to shift fast. when you can shift fast enough it wont matter if you have the gas on the floor through the shift or not.
yah i was jus wondering about it
u think if i got hondata i can get up to 10 more horses?
Modified by CrxStreetRacer at 9:55 PM 4/14/2004
</TD></TR></TABLE>yah i was jus wondering about it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxStreetRacer »</TD></TR><TR><TD CLASS="quote">
Yah i kno thats how i do it but i was just wondering about it but if i got hondata could i get like up too 10 hp and where can u buy one?</TD></TR></TABLE>
Jesus F'ing Christ
stan
Jesus F'ing Christ
stan
^^ patience, patience
its possible ya. hondata doesnt just add h/p. it gives you the ability to tune the motor to put out the max hp/trq possible. so if your pretty un tuned ya its possible to get another 10hp maybe more
i think your talking about the staging mod? the vid with the guy just sitting witht he door open holding the car and the car kinda sounds like its bumping off the rev limit? well he's not reving the car to full throttle its a mod used for staging that allows you to press for full throttle while the hondata controls the actual amount of rpm used for your launch.
press cluch to activate hondata switch, press gas to full, hondata controls rev to your set amount...say 4500rpm, green light, let go of clutch, your at full throttle automatic. thats how it works in a nut shell
post a link to the vid your talking about.
honestly from the way your talking i think a hondata might be out of your league. if you get a hondata system it will allow you to tune your motor to work at full potential. if you have never tuned you will need to learn from an experienced tuner that can show you the odds and ends of the hondata spectrum. you will not gain 10hp just by purchasing a hondata it doesn't work that way.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgonzals »</TD></TR><TR><TD CLASS="quote">gave u tried the local shop yet in your area, i can tell u grip in so cal...but u are not down here.....</TD></TR></TABLE>
Yah i am nor but i want a good shop and someone knows about them to help me out
Damn.. Do you really have whats in your sig, or is that just a wish list? Becuase if you really have that stuff and don't know whats going on right now, please step away and search more.. jesus more and more people with more money than brains latley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxStreetRacer »</TD></TR><TR><TD CLASS="quote">who said i had alot of money stuff i have on my crx been over a period of time,hard working overtime</TD></TR></TABLE>
You just gave me a headache.. thanks
Werd. Headache here too....
Hondata does not add horsepower, not tuning takes it away. Theres a difference.
Think of it this way, Hondata will basically in the end control the a/f mixture. That's where your Horsepower gain comes from. If you can control the a/f mixture with something else for cheaper (like your AFC) then use that. But first, go learn about tuning, I'm a newb myself but if you've got what your sig lists then that sounds liek about 5 grand into a CRX with an ignorant owner.
b00sted_GS-R
Jan 5, 2005 07:08 AM
