o2 sensor..new or used?
Old Apr 13, 2004 | 04:17 PM
cpxek9's Avatar
Default o2 sensor..new or used?
o2 sensor gone bad. i need 1 to pass smog...costs $200 from the dealer!!! should i just get 1 new or goto a junk yard and get a used 1?
Old Apr 13, 2004 | 04:55 PM
vtec.com's Avatar
cant go wrong with used, might be messed up or broken. i'd go with new.
Old Apr 13, 2004 | 05:06 PM
Ape's Avatar
Ape
Default Re: (vtec.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.com &raquo;</TD></TR><TR><TD CLASS="quote">cant go wrong with used, might be messed up or broken. i'd go with new.</TD></TR></TABLE>
So wouldnt that be you can go wrong.. if theres a chance of it being broke.
Old Apr 13, 2004 | 05:07 PM
Jmunk's Avatar
http://www.oxygensensors.com
Old Apr 13, 2004 | 05:09 PM
stuck209's Avatar
Check out our sponser marketplace. Prostreetonline has a buy out for less then what you were quoted at the dealer.
Old Apr 13, 2004 | 07:10 PM
cpxek9's Avatar
a friend said its $40 at the local autozone .. think its a good idea to get it at autozone?
Old Apr 13, 2004 | 07:24 PM
Combustion Contraption's Avatar
thats the universal one. unless your good at wiring and reading wiring diagrams, buy the OEM one, its a no brainer.
Old Apr 13, 2004 | 07:32 PM
Race Egr's Avatar
Default Re: (LsVtec92Hatch)
I have one for 20 shipped came out of my wrecked ek pm me if u want it
Old Apr 30, 2004 | 12:49 PM
DubyaAye's Avatar
Default Re: (ek-guru)
damn i didnt know o2 sensors cost that much.
Old Apr 30, 2004 | 02:05 PM
DJ_SaNdOz's Avatar
Default Re: (DubyaAye)
I got a bosch 02 sensor from autozone that was already setup as an oem replacement for $76 incl tax.....
Old May 1, 2004 | 08:41 AM
New Image's Avatar
Default Re: (DJ_SaNdOz)
if you get a used one make sure it is in alright shape. but if you can afford it a new one might be the way to go. good luck.
Old May 1, 2004 | 08:46 AM
E-brake or Handbrake's Avatar
Default Re: (94JDMEG)
Borrow a "known-good" o2 sensor from a friend to pass smog if you're low on funds, then go and get the universal one from Autozone to run for awhile. If you don't want to go through the hassle, just get a new one. You'll save time & not to mention gas from the newly replaced sensor. I personally wouldn't run Autozone o2 sensors...
jdm24seven
26
Jan 27, 2008 06:35 AM
saywhat
Feb 8, 2005 02:28 PM
integraguy2001
Dec 16, 2004 06:13 PM
mugenhatch92
Aug 28, 2004 01:27 PM
senpai
Jun 18, 2004 07:10 AM
