Wideband + Uberdata + o2 heater
Old Jun 17, 2004 | 08:46 AM
senpai's Avatar
Default Wideband + Uberdata + o2 heater
Okay, I've got an Uberdata-chipped ecu. My car throws a o2 heater CEL, I don't know why maybe my o2 sensor is fugged.
Anyhoot, I'm looking at getting a wideband and replacing the narrowband o2 completely. (2 birds with one stone) Now if I check "O2 Heater Disable" in Uberdata, then I can ignore the wiring in the resistor in this diagram?
Anyone doing the same, no problems?
Old Jun 17, 2004 | 08:50 AM
dennis's Avatar
Default Re: Wideband + Uberdata + o2 heater (maztur)
good question... bump. I'm guessing we'd "check" O2 heater disable, but like to hear for sure. Are you talking about getting the O2 signal from your wideband's narrowband output?
Old Jun 17, 2004 | 08:54 AM
ion_four's Avatar
Default Re: Wideband + Uberdata + o2 heater (dennis)
I think o2 disable merely means that the ecu will be running in open loop all the time, so you'll probably get really had mileage. Otherwise, you're golden!
Old Jun 17, 2004 | 09:02 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">good question... bump. I'm guessing we'd "check" O2 heater disable, but like to hear for sure. Are you talking about getting the O2 signal from your wideband's narrowband output?</TD></TR></TABLE>
Yes I am! Like I said: 2 birds, 1 big stone EDIT: I also don't have to weld in another o2 bung
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">I think o2 disable merely means that the ecu will be running in open loop all the time, so you'll probably get really had mileage. Otherwise, you're golden! </TD></TR></TABLE>
Well, Uberdata also has "Closed Loop Disable" so I dunno...
Old Jun 17, 2004 | 09:08 AM
Mad Cow's Avatar
o2 heater disable means simply that, it will disable the o2 heater. You won't get a code for it if it's disabled.
Right now I'm running without it disabled so I get the CEL...
Old Jun 17, 2004 | 09:25 AM
tegmech's Avatar
are you going to run a narrowband simulator to your ecu?
Old Jun 17, 2004 | 12:43 PM
dennis's Avatar
Default Re: (tegmech)
He doesn't want to simulate narrowband. He wants to use the narrowband output of his wideband in place of the stock narrowband OS to drive the ECU.
Old Jun 17, 2004 | 01:36 PM
dsadas89das78934's Avatar
Default Re: (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">He doesn't want to simulate narrowband. He wants to use the narrowband output of his wideband in place of the stock narrowband OS to drive the ECU.</TD></TR></TABLE>
yeah... the narrowband output of the WBO2 unit is 'simulated' because it's not a true 0-1v signal... it has to be interpolated from the raw 0-5v input from the wbo2 sensor
edit... whoops... read your comment slightly out of context, my bad.
but yes, with the o2 heater disable you do NOT have to wire the resistor as shown in the picture
Old Jun 17, 2004 | 06:23 PM
blackeg's Avatar
Default Re: (soccaian)
apologies if this is a jack- but it might be slightly relevant. if i were to remove the narrowband o2 and install a wideband just to datalog for like 10 minutes, would i check o2 sensor disable and heater disable also?
Old Jun 17, 2004 | 11:01 PM
leed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone doing the same, no problems? </TD></TR></TABLE>
Yes. Disabled O2 heater in Uber. PLX simulated 02-NB to the ECU. All is well.
Old Jun 17, 2004 | 11:05 PM
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">apologies if this is a jack- but it might be slightly relevant. if i were to remove the narrowband o2 and install a wideband just to datalog for like 10 minutes, would i check o2 sensor disable and heater disable also? </TD></TR></TABLE>
yeah, just check the o2 heater disable box, burn the chip, and be on your way
Old Jun 18, 2004 | 06:01 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, just check the o2 heater disable box, burn the chip, and be on your way</TD></TR></TABLE>
. thank you
Old Jun 18, 2004 | 06:33 AM
Muckman's Avatar
Moderator in Chief
Whats the deal with that resistor between your O2 Heater and ground wires?
Old Jun 18, 2004 | 07:10 AM
Mad Cow's Avatar
Default Re: Wideband + Uberdata + o2 heater (Muckman)
Tricks the ECU into thinking that it's heating the o2 sensor, when it is infact only heating your resistor(s). Be careful with this method, the resistors will get hot and melt stuff if you're not careful.
s2k drifter
Mar 30, 2005 01:11 PM
red_crx
Nov 26, 2004 04:38 AM
Qwikrex
Jul 31, 2002 09:53 PM
