rear toe adjustment. need answer quick.
Old Apr 13, 2004 | 08:51 AM
asmallsol's Avatar
Default rear toe adjustment. need answer quick.
On adjusting rear toe, to make it more positive, would you move the adjuster more to the outside of the car, or in towards the center of the car. Need answer very quick.
The reason why I ask, is I looked over my alignment sheet from the last time I got it aligned, and there is -.78 degrees of toe. I looked at my toe adjuster for that wheel, and it is maxed out to the inside of the car (all the way to the right, on the driverside, if your looking at it from the rear)
My one tire is pretty much fucked, so if they adjusted it wrong, I will say there techs are at fult, and they need to fix that tire.
Old Apr 13, 2004 | 08:55 AM
t0p_sh0tta's Avatar
Default Re: rear toe adjustment. need answer quick. (asmallsol)
negative is always towards the "hood ornnament" IIRC.
Old Apr 13, 2004 | 08:58 AM
asmallsol's Avatar
Default Re: rear toe adjustment. need answer quick. (t0p_sh0tta)
so if it is all the way to the right, and I have negative toe, they did it wrong correct?
Old Apr 13, 2004 | 09:02 AM
slammed_93_hatch's Avatar
not true, it may have needed to be moved that far in, i dunno but it is possible
Old Apr 13, 2004 | 09:05 AM
asmallsol's Avatar
Default Re: rear toe adjustment. need answer quick. (slammed_93_hatch)
but If I needed postive, and they moved it all the way to the negative, wouldn't that be wrong. On the sheet, it says "before -.74, after -.78" this means that they added negative toe, when honda calls for +.04 degrees.
Old Apr 13, 2004 | 09:12 AM
well then it appears your correct why didn't you state your original number in the first post
Old Apr 13, 2004 | 09:32 AM
asmallsol's Avatar
well, now that I have my answer, I am going to firestone, to yell at them, and maybe get discount tires out of it. My potenza s03's had a decent amount of tread before I went to them. Now they are just gone on the inside.
lurice01
May 14, 2018 01:49 AM
FreshJr
Feb 14, 2014 06:22 PM
EK_B
Suspension & Brakes
Oct 15, 2007 11:34 AM
Chim Chim
Suspension & Brakes
14
May 9, 2007 03:12 PM
CivicSiRacer
10
May 2, 2004 01:50 AM
