Hows my alignment? Do I need the frame pulled?
Hello everybody, this is my first post and lets just say I hooked a bump in the road.
Can you guys tell me if I am reading my alignment sheet correctly. It seems my front caster is off and my rear chamber doesn't match.
Do I need the front left of the car pulled up (towards the driving direction), to get the casters closer to each other?
Do I need the rear left pulled out (more left), to get the rear left chamber more positive, and the left more negative.
What I am talking about strapping the car to a frame puller and pulling the rear and front sub frames.
I know a person with a body shop but I dont know if these values are so out of spec that I should ask him for a quote.
Paper does show all green but I dont quite agree.
Re: Hows my alignment? Do I need the frame pulled?
You want less caster on the left side, it will help counter the crown of the road. Perfectly normal, your alignment is fine
You could probably drop the front camber out .2 or .3 by loosening the bolts on the bottom of the strut with the weight off the suspension (jacked up by the subframe, not the control arm). There is usually enough slop in the knuckle/strut to allow for some minor adjustments. The rear is a different story since it's multi-link. Set the toe and go.
And for reference, if it were necessary to shift the frame, most frames do not need to be "pulled" but rather simply loosen the bolts and shift the frame with a couple of large pry bars.....
I forgot, accords stayed with the double wishbone front suspension for a while, in which case no camber adjustments are available as it comes from the factory. Not sure which model you have, so it will vary depending on application
My Name is Nobody
you wouldn't need to have your frame pulled even if you wanted to change those specs... they would need to do a sub frame adjustment by loosening and moving the front and rear sub frames. not a big deal.
Im trying to bring the caster to 4* each. So push driver side forward and passenger side back.
It does pull left right now, going to toe adjust on rear tmrw.
-.6 caster split is fine...I'd suspect more of a tire issue than anything else. Hondas don't usually pull even if the alignment is wayyyyy off; 99% of the time I find that rotating the tires fixes the problem. FWD cars tend to track straighter since the drive wheels are also the steering wheels.
lurice01
05-14-2018 01:49 AM
