Which ECU to use with JDM D15B with bolt ons?
P08 is great... as it uses only 1 wire 02 sensor. it is also mapped much leaner then P28, with more timing advance.
other great options are the Spoon chip. very mild but aggressive enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kruzen510 »</TD></TR><TR><TD CLASS="quote">don't waste your money buying boltons for a d15, just get a b-series motor, you'll be much happier</TD></TR></TABLE>
Why does everyone say that?
Im running a P28, but its all mapped and chipped for my turbo, so its different a bit. Everyone I know running this setup so far is still on the p28, i hadnt heard of people using the p08 until recently.
nice 1st post idiot. do us all a favor a dont post again. I'd think the p28 would be good I am not familiar with the P08
For your 1994 Civic CX, use the ECU that comes with the engine (if it is OBD-1), otherwise use a P28 from a '92-95 D16Z6-powered car (Civic Si/EX or del Sol Si).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">For your 1994 Civic CX, use the ECU that comes with the engine (if it is OBD-1), otherwise use a P28 from a '92-95 D16Z6-powered car (Civic Si/EX or del Sol Si).</TD></TR></TABLE>
yeah dont use that garbage *** p07 ecu that comes stock in a CX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice »</TD></TR><TR><TD CLASS="quote">
yeah dont use that garbage *** p07 ecu that comes stock in a CX. </TD></TR></TABLE>
P07 comes in VX if I'm not mistaken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">
correct...cx is p05
</TD></TR></TABLE>correct...cx is p05
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">
correct...cx is p05</TD></TR></TABLE>
BOO
worst ECU eva
BOO
worst ECU eva
wow stfu unless u nkow what ur talkin bout, call me once uve done your big bad b-series swap and after ive put in the same amt of money u used on the b series swap scouts honor ill blow ur ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcivic95 »</TD></TR><TR><TD CLASS="quote">
wow stfu unless u nkow what ur talkin bout, call me once uve done your big bad b-series swap and after ive put in the same amt of money u used on the b series swap scouts honor ill blow ur ***</TD></TR></TABLE>
Online bench racing makes you sound just as dumb as him. Why bother to evben respond to such an obviously stupid claim?
ya your best bet is the P28, and the best power for your bang for you buck would be the JUN for the p28, it sucks on Bseries, but it ripps on SOHC's thats the chip i run with my mild built z6
aberfoyle
Dec 13, 2004 12:37 PM
