Chipped ECU???????
Old Aug 5, 2007 | 04:54 PM
jarven093's Avatar
Default Chipped ECU???????
i have a D16Z6 turbo'd civic 93' and am needing a chipped ecu and was needing to know if i can buy a chipped ecu and just plug and play or dose it have to be tune to the motor ? what should i look for in a Chipped ecu ( my stock one is a P28) ....... just looking for some info ? thanks
Old Aug 5, 2007 | 05:00 PM
93turbo16's Avatar
Default Re: Chipped ECU??????? (jarven093)
You will want a chipped P28 ecu or P28 equivalent ecu that has vtec functions. Most people can provide you with a basemap that will run your car, but it is always highly recommended to get your car tuned.
Old Aug 5, 2007 | 05:26 PM
xenocron's Avatar
Default Re: Chipped ECU??????? (93turbo16)
There is no substitute for tuning...every car/setup has something that will run slightly different.
Old Aug 5, 2007 | 06:41 PM
mtber's Avatar
Default Re: Chipped ECU??????? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">There is no substitute for tuning...every car/setup has something that will run slightly different.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">You will want a chipped P28 ecu or P28 equivalent ecu that has vtec functions. Most people can provide you with a basemap that will run your car, but it is always highly recommended to get your car tuned.</TD></TR></TABLE>
+2
You can have your stock p28 ecu chipped/socketed with a basemap.
You should make sure you have the proper sized map sensor, injectors & fuel pump for your setup before you get your car tuned
Old Aug 5, 2007 | 08:41 PM
garrettej8's Avatar
B A N N E D
slightly off topic but if I have a p75 ecu for a 97 b18b do I have to use a chipped p75 or can I use a chipped p28 ecu as an option as well?
Old Aug 5, 2007 | 09:17 PM
93turbo16's Avatar
Default Re: (garrettej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrettej8 &raquo;</TD></TR><TR><TD CLASS="quote">slightly off topic but if I have a p75 ecu for a 97 b18b do I have to use a chipped p75 or can I use a chipped p28 ecu as an option as well?</TD></TR></TABLE>
You can use the P28 on a non-vtec motor if you disable all the vtec parameters, so the ecu doesn't look for it.
tmk819
Dec 11, 2006 07:35 AM
rockthegens
Aug 23, 2005 08:11 AM
havalilsi
Oct 4, 2004 11:57 AM
gookspeed
May 15, 2004 02:58 AM
Jasper_db1
Feb 5, 2004 04:18 PM
