Which ECU for tuning?
Old Apr 14, 2007 | 09:24 AM
92hatch_cx-t's Avatar
Default Which ECU for tuning?
I have a p28 ecu but i also have a p05. does it matter which ecu i use? because i rather use the p05 and dont touch the p28.
thanks
Old Apr 14, 2007 | 09:42 AM
t3b18b's Avatar
Default Re: Which ECU for tuning? (92hatch_cx-t)
dude go with the p28. by far the best ecu to tune for dohc honda motors. i have one running my ls turbo w/o vtec and it runs great. if you have a dohc vtec motor it will work great. as far as chipping. dont mess with that you need chrome pro. the chips you buy off of ebay are not specifically designed for your setup or mods and can really mess up your engine by being programmed either too rich or too lean. if your looking into engine management for your honda then look into chrome or uberdata. cant go wrong
Old Apr 14, 2007 | 09:43 AM
t3b18b's Avatar
Default Re: Which ECU for tuning? (t3b18b)
by the way what motor do you have?
Old Apr 14, 2007 | 11:38 AM
b18b1turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatch_cx-t &raquo;</TD></TR><TR><TD CLASS="quote">I have a p28 ecu but i also have a p05. does it matter which ecu i use? because i rather use the p05 and dont touch the p28.
thanks</TD></TR></TABLE>
dont matter which one you use...both the same...you can chip the p28 or p05 for vtec or non-vtec.
Old Apr 14, 2007 | 04:21 PM
skUnK2jdm's Avatar
Default Re: Which ECU for tuning? (b18b1turbo)
p28 is the most commonly used for dual cams because they have the best air fuel mixture
Old Apr 14, 2007 | 04:29 PM
nowtype's Avatar
Default Re: Which ECU for tuning? (skUnK2jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">p28 is the most commonly used for dual cams because they have the best air fuel mixture</TD></TR></TABLE>
Quoted for the truth.
Old Apr 14, 2007 | 04:30 PM
bigbadboy's Avatar
if your going to install honda or something like that its easier to use the p28 but you can also turn the p05 into p28 specs and it will be the same stuff
Old Apr 14, 2007 | 04:36 PM
doood's Avatar
been there done that
Default Re: Which ECU for tuning? (nowtype)
when chipped and tuned it doesnt matter
Old Apr 14, 2007 | 06:23 PM
its a d16z6 with a y8 head. i want to boost like 8 pounds. i want to tune with neptune. the reason why i dont want to use the p28 is because if one day i take of the turbo i dont want to have to look for another p28.
Old Apr 14, 2007 | 06:30 PM
nowtype's Avatar
Default Re: (92hatch_cx-t)
=blown engine
Old Apr 14, 2007 | 06:38 PM
Default Re: (nowtype)
any good reasons?
Old Apr 14, 2007 | 06:46 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">=blown engine</TD></TR></TABLE>
wtf?
Old Apr 14, 2007 | 06:57 PM
mtber's Avatar
p06/p05 with vtec added, p28, p72, they all have the same common concept.
Read http://phearable.net/tech/efibeginnerguide.html
Old Apr 14, 2007 | 07:38 PM
avotegra's Avatar
what kind of tuning is this........neptune, chrome pro, uberdata are they just like hondata with the tuning of a laptop to or but tuning with a clip and put into the ecu
Old Apr 14, 2007 | 08:13 PM
bigbadboy's Avatar
if your going to boost you have to get tuned no matter wat. so just choose a system that fits your budget and look for the tuner. get your p05 converted to p28 specs that way you can leave your p28 a virgin for later use or emergency use, ect.
Old Apr 14, 2007 | 09:39 PM
alphajesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatch_cx-t &raquo;</TD></TR><TR><TD CLASS="quote">its a d16z6 with a y8 head. i want to boost like 8 pounds. i want to tune with neptune. the reason why i dont want to use the p28 is because if one day i take of the turbo i dont want to have to look for another p28.</TD></TR></TABLE>
That doesn't make any sense.
If you want to run the stock program again, just cut J1. Voila! Back to stock!
BTW, neptune is a pretty kick-*** system, you'll love it.
Old Apr 14, 2007 | 10:59 PM
Default Re: (alphajesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, neptune is a pretty kick-*** system, you'll love it.</TD></TR></TABLE>
well i just wanted to leave my p28 virgin. but i didnt know you could do that
thanks for all the advice. once again im going to use neptune.
hybrid_vtec
16
Feb 3, 2013 07:38 AM
Freckles
20
May 3, 2012 06:17 AM
Lasky
Nov 9, 2007 11:29 AM
gookspeed
May 15, 2004 02:58 AM
Jasper_db1
Feb 5, 2004 04:18 PM
