IDLING QUESTION...
Old Apr 12, 2004 | 02:03 PM
crzyfool24's Avatar
Default IDLING QUESTION...
Whenever I come to a stop or a light or where ever...My car idls up and down. I'm not pushing the gas or anything. It idls up to 1200 then back down so low that I think my car is going to stall then back up. Anyone know what this could be? Thanks.
Old Apr 12, 2004 | 02:17 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: IDLING QUESTION... (crzyfool24)
I have had this happen with a vac. leak. That will usually cause uneven idle. Another more scary problem is a faulty head gasket. I blew a SOHC motor this way before...
Old Apr 12, 2004 | 02:19 PM
JDMlyfestyle's Avatar
check your IACV. and it sounds like your idle adjuster screw might be set to low as well.
Old Apr 12, 2004 | 02:21 PM
crzyfool24's Avatar
Default Re: (JDMlifestyle)
where is this idle adjuster screw? If it a vac leak...Where could I find it? Thanks.
Old Apr 12, 2004 | 02:41 PM
Default Re: (crzyfool24)
Vac leaks are sort of guess and check unless your car is throwing a code. The idle adjustment screw is on the throttle body. More towards the firewall but facing the passanger side of the vehicle
Old Apr 12, 2004 | 02:42 PM
Default Re: (HondaFanatic708)
I would certainly check the Idle Air Control Valve. Even in the Honda manual it notes to be very careful with this component.
Old Apr 13, 2004 | 10:59 AM
crzyfool24's Avatar
Ok...I will go check that screw. What is the Idle Air Control Valve? Where is it?
thekid2390
Apr 11, 2013 11:25 AM
Midori Green
Jan 3, 2007 03:13 PM
delguiner
Apr 7, 2004 12:50 PM
4gen
Jan 11, 2004 05:28 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
