What is the stock oil pressure (B18B) ??
I search through the Helms manual before and never found anything on oil pressure. This is all I can find and I saved it in notepad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Engine Oil Pressure:
At idle: 70 kPa (10 psi) minimum
At 3000 rpm : 340 kPa (50 psi) minimum</TD></TR></TABLE>
The oil pressure in my ls reads 80psi while warming up 18-20psi @idle and80-90psi when th rpms climb up.....could my oil pressue guage be messed up its 3 months old but have the same readings all the time. its a regular needle one
