List of codes from OBD2 scanner... help :(
well... after cleaning the TB, i have idle troubles... got it scanned today, here are the list of codes
P0108- MAP Sensor
P0122- Throttle Positioning Sensor
P0505- ICS Malfunction
P0141- o2 heater circut bank 1 snsr 2 ( this could be from an earlier problem)
P1337- Undefined code...
Havnt had it reset in a long while, so some may be old...
Can the two sensors be cleaned .. or should they be replaced?
P0108- MAP Sensor
MAP and TPS sensor plugs could be flip-flopped if you've played with them recently.
TPS has a red/blk middle wire.
1336 is for the CKF sensor. It's showing an intermittent signal.
make sure your tps and map plugs arent swapped like in vtec said (i did that when i put a new tb on) and reset your ecm so you know if codes are old - you shouldn't need new sensors unless you took them off or beat the **** out of them when cleaning the tb
EK9ED
10
Oct 26, 2009 04:43 PM
