map sensor problem
Old Aug 14, 2014 | 01:14 PM
jdmacuraITR's Avatar
Default map sensor problem
CEL came on and it was map sensor then i replaced it then reset it with the code reader and it still pop back up and it run rich and get bad gas mileage... i dont know what it is... map sensor or i got to replace the harness because i previous owner splice wire on the icav
Old Aug 14, 2014 | 01:25 PM
Default Re: map sensor problem
Anybody please
Old Aug 14, 2014 | 06:27 PM
No body has a anwser?!!
Old Aug 14, 2014 | 07:03 PM
B_Swapped93's Avatar
make sure that little o-ring is not deteriorated/missing
Old Aug 15, 2014 | 12:43 PM
wunfstgsr's Avatar
Loved
Community Favorite
that and try a new map sensor..
Old Aug 15, 2014 | 04:25 PM
greatnightmare's Avatar
Is there a code for tps also?
Old Aug 15, 2014 | 04:34 PM
yes, but what do you mean the previous owner spliced it with the IACV...pic
Old Aug 15, 2014 | 08:27 PM
No i just got a new oring
Old Aug 15, 2014 | 08:28 PM
it did before till i replace it
Old Aug 15, 2014 | 08:29 PM
like the previous owner put some new wire on icav but i dont know if that has anything to do with it and i will post a pic tomorrow
Old Aug 15, 2014 | 08:31 PM
Hope this help it has a blox throttle body and a skunk2 pro series maniflod and a vtec control that controll air to fuel ratio
Old Aug 15, 2014 | 08:36 PM
you're supposed to run at the very least a basemap when you switch intake manifolds/increase tb size.
that's unrelated but advice non the less. until we get a better idea of these spliced plug not much to suggest.
Old Aug 15, 2014 | 08:39 PM
the throttle body and manifold came with the car when i bought it
Old Aug 15, 2014 | 08:44 PM
well running rich is the same as bad mpg, look into what ECU you have in the car the map could not actually be bad rather something throwing it.
Old Aug 15, 2014 | 08:54 PM
Alright i will check but can a vtec controller make it mess up too (came with the car too)
Old Aug 15, 2014 | 08:57 PM
Ohhh god get rid of that thing before anything else is done, those things are as old school as they get.
Old Aug 15, 2014 | 09:02 PM
lol is that bad?
Old Aug 15, 2014 | 09:05 PM
And it is an APEXI AFC NEO
Old Aug 15, 2014 | 09:12 PM
Originally Posted by jdmacuraITR
lol is that bad?
it's junk you can search as to why
And it is an AFC something dont know what it is
VAFC(VTEC AIR FUEL CONVERTER) aka "vtec controller"
Old Aug 15, 2014 | 09:31 PM
I will just sell it to my friend thank for help
92ehatch
16
Feb 19, 2007 11:41 PM
Driven
Nov 24, 2003 01:13 PM
civic1990si
Jan 27, 2003 07:56 PM
