car sputters after a few gears of boost
Old Apr 11, 2004 | 03:22 PM
mrbsponge's Avatar
Default car sputters after a few gears of boost
hey all i have a 99 b16 with a custom turbo set up on it, currently i am running a vafc and RC 440s, i do have a missing link, and am running 12psi, on a t3t4.
after i blast about 3 gears, my car throws a map sensor code.....i dont know why because i am running 12psi, with a missing link..
someone told me that it was because the vafc is pulling or pushing too much fuel, but i dont know.
i know there are hondas out there running more boost than me without standalone, so what am i to do??????
Old Apr 11, 2004 | 03:40 PM
highmilehatch's Avatar
Default Re: car sputters after a few gears of boost (mrbsponge)
All I can suggest, is to get rid of that setup and invest in a Hondata S100. I know it's not the answer your looking for but it is what I would suggest. Spend the money now or spend it later.
Old Apr 11, 2004 | 03:45 PM
Hoosier Daddy's Avatar
Does the car sputter/run horribly until you turn it off, then on again? If so, it's definitely your map sensor. I don't know why it would be coding if you're using a missing link, then again I have no experience with missing links. You can always pick up a GM 3bar MAP.
Old Apr 11, 2004 | 04:29 PM
mrbsponge's Avatar
yeah after i cut it off then on again, its fine....does a GM 3bar work on a stock set up? i didnt think they did, im not sure if the factory ecu, can read anymore than 1 bar, but im not really @ 1 bar yet, so i dont know what to do.
i know i should get some hondata or something of that sort, but i need a temporary fix to get me by
Old Apr 12, 2004 | 08:43 AM
mrbsponge's Avatar
ttt
Old Apr 12, 2004 | 09:16 AM
b16hybridsol's Avatar
Default Re: (mrbsponge)
stock map sensor is only good for 11.8psi
l2yanE
Oct 2, 2005 10:15 AM
redlseg
Apr 26, 2005 07:20 AM
94greddycivic
Jun 29, 2004 10:51 AM
dc r-spec
Jun 4, 2002 11:36 PM
