gsr hatch keeps on wanting to over heat??????
Old Apr 10, 2004 | 12:58 PM
pnltnc's Avatar
Default gsr hatch keeps on wanting to over heat??????
Yah I have a 93 hatch with a gsr complete swap using a stock radiater. I changed the thermastat today, and she still wants to over heat. Any other suggestions?
Old Apr 10, 2004 | 01:02 PM
Sasebonian's Avatar
Default Re: gsr hatch keeps on wanting to over heat?????? (pnltnc)
Assuming the fan switch is good, I would check you're radiator.
Hmmm trying switching to a dual core radiator. From what I remember, civics that didn't have a vtec engine had single core radiators.
Old Apr 10, 2004 | 01:04 PM
pnltnc's Avatar
Default Re: gsr hatch keeps on wanting to over heat?????? (Sasebonian)
really?? I have the gsr radiator to, maybe I should try that... What do you think?
pnltnc's Avatar
How do you check the fan switch?
Old Apr 10, 2004 | 01:05 PM
Ricey McRicerton's Avatar
Do your fans come on at all? Are your fans good?
Old Apr 10, 2004 | 01:12 PM
b-powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnltnc &raquo;</TD></TR><TR><TD CLASS="quote">How do you check the fan switch?
run ur car for 10 min or so at 2000 rpm to see if fan comes on or see if ur fan clip is hooked up.. or u can have air pockets in ur system.. to fix that let oprn ur radiator cap and idle of 20 min or so keep filling it up with rad, fluid.. by the way switch to a dual core.. 92-95 auto civic vtec.. call 1800 radiator.. it was the cheapest ive found even with shop discounts. 115 bucks i believe. but if u got a gsr rad. i would have that is depending if u got a/c or not..
Old Apr 10, 2004 | 01:17 PM
Default Re: gsr hatch keeps on wanting to over heat?????? (b-powa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-powa &raquo;</TD></TR><TR><TD CLASS="quote">
run ur car for 10 min or so at 2000 rpm to see if fan comes on or see if ur fan clip is hooked up.. or u can have air pockets in ur system.. to fix that let oprn ur radiator cap and idle of 20 min or so keep filling it up with rad, fluid.. by the way switch to a dual core.. 92-95 auto civic vtec.. call 1800 radiator.. it was the cheapest ive found even with shop discounts. 115 bucks i believe. but if u got a gsr rad. i would have that is depending if u got a/c or not..</TD></TR></TABLE>
Wow...just wow.
Yes, he's right about checking to see if the fans come on. And if your fans come on then you need to bleed the air out of the system. *LET THE CAR COOL BACK DOWN FIRST!!!* and then pull the radiator cap off and let it idle for a while letting it burp all of the air out.
And if you already have the GSR radiator in, leave it. And 115 bucks for that dual core radiator is not all that good at all.
Old Apr 10, 2004 | 01:19 PM
OnePointFive's Avatar
overrated.
Default Re: gsr hatch keeps on wanting to over heat?????? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
And 115 bucks for that dual core radiator is not all that good at all. </TD></TR></TABLE>
hell no it isn't, you can get a dual core off radiatorbarn.com for like 85...
Rodolfo Rivera
Honda CR-V & Element
Oct 10, 2017 05:54 PM
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
dman81
May 28, 2014 03:20 AM
chuniepatuni
Dec 5, 2006 07:09 PM
not so civic
Jul 3, 2001 09:32 AM
