gsr hatch keeps on wanting to over heat??????
Yah I have a 93 hatch with a gsr complete swap using a stock radiater. I changed the thermastat today, and she still wants to over heat. Any other suggestions?
Re: gsr hatch keeps on wanting to over heat?????? (pnltnc)
Assuming the fan switch is good, I would check you're radiator.
Hmmm trying switching to a dual core radiator. From what I remember, civics that didn't have a vtec engine had single core radiators.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnltnc »</TD></TR><TR><TD CLASS="quote">How do you check the fan switch?
run ur car for 10 min or so at 2000 rpm to see if fan comes on or see if ur fan clip is hooked up.. or u can have air pockets in ur system.. to fix that let oprn ur radiator cap and idle of 20 min or so keep filling it up with rad, fluid.. by the way switch to a dual core.. 92-95 auto civic vtec.. call 1800 radiator.. it was the cheapest ive found even with shop discounts. 115 bucks i believe. but if u got a gsr rad. i would have that is depending if u got a/c or not..
Re: gsr hatch keeps on wanting to over heat?????? (b-powa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-powa »</TD></TR><TR><TD CLASS="quote">
run ur car for 10 min or so at 2000 rpm to see if fan comes on or see if ur fan clip is hooked up.. or u can have air pockets in ur system.. to fix that let oprn ur radiator cap and idle of 20 min or so keep filling it up with rad, fluid.. by the way switch to a dual core.. 92-95 auto civic vtec.. call 1800 radiator.. it was the cheapest ive found even with shop discounts. 115 bucks i believe. but if u got a gsr rad. i would have that is depending if u got a/c or not..</TD></TR></TABLE>
Wow...just wow.
Yes, he's right about checking to see if the fans come on. And if your fans come on then you need to bleed the air out of the system. *LET THE CAR COOL BACK DOWN FIRST!!!* and then pull the radiator cap off and let it idle for a while letting it burp all of the air out.
And if you already have the GSR radiator in, leave it. And 115 bucks for that dual core radiator is not all that good at all.
Wow...just wow.
overrated.
Re: gsr hatch keeps on wanting to over heat?????? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
And 115 bucks for that dual core radiator is not all that good at all. </TD></TR></TABLE>
hell no it isn't, you can get a dual core off radiatorbarn.com for like 85...
Rafe Altschuler
14
08-11-2015 04:10 PM
chuniepatuni
12-05-2006 07:09 PM
not so civic
07-03-2001 09:32 AM
