Radiator Fan Not Functioning. Really Stumped.
Old 08-11-2015, 09:09 AM
Rafe Altschuler's Avatar
Default Radiator Fan Not Functioning. Really Stumped.
Hey everyone. I have a 1993 Honda Del Sol and recently replaced the radiator. The old radiator cracked because it turns out the radiator fan was not functioning. I'm trying to figure out what the issue is and through various tests I've determined that the fan itself functions, the fan relay is functioning, and the cooling fan switch is functioning. Any ideas for what would be causing my fan to not function? Thanks.
Old 08-11-2015, 09:40 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: Radiator Fan Not Functioning. Really Stumped.
the temp itself. does it get to the correct temp. if so. is that communicating with the switch? cracked plastic? get aluminum radiator
Old 08-11-2015, 09:45 AM
I've stated that I replaced the radiator. I don't need to blow more money on an aluminum one. The engine gets to running temperature and the radiator fan doesn't kick on.
Old 08-11-2015, 09:52 AM
Neth's Avatar
check the plastic around the connector is it damaged? burnt/melted? clean the inside of the connector and make sure it's getting good contact.
Old 08-11-2015, 09:54 AM
I'm not Rick!
right but replaced with another plastic top and bottom. they all crack.
Old 08-11-2015, 10:04 AM
Yes, the temperature reaches beyond the point where the fan should kick on.
Old 08-11-2015, 10:47 AM
donut.'s Avatar
Have you checked the fuse for the fan? Should be a 15amp
Old 08-11-2015, 11:09 AM
None of the fuses are blown.
Old 08-11-2015, 11:52 AM
donut.'s Avatar
Well somethings missing.
How did you perform these various tests? How did you determine the fan switch works?
Old 08-11-2015, 12:00 PM
I checked the fan unit itself by connecting it to the battery: It works.
I checked the relay by bypassing the fan switch: It works.
The fan switch itself is brand new (I decided to replace it along with the radiator), and I checked the resistance on it, and it seems to be correct.
Old 08-11-2015, 12:23 PM
donut.'s Avatar
Well i'm not sure. Let us know when you figure it out. Good luck.
Old 08-11-2015, 01:21 PM
cvcrcr99's Avatar
How quickly does it hit operating temperature? does the gauge show over halfway on the dash board? Are you overheating during idle (traffic), on the high way, or both? If the car is stock, or relatively stock, an OEM radiator should be just fine.
Old 08-11-2015, 01:27 PM
The car is pretty much stock, engine-wise. It heats up normally, but I'll take it out, drive it for about fifteen minutes in summer heat, pull over and check to see if the fan is running, and it isn't. So something isn't clicking in the system.
Old 08-11-2015, 04:09 PM
Technical Hero
HondaPartsHero's Avatar
Did you properly bleed the system?
Old 08-11-2015, 04:10 PM
Yep.
dman81
05-28-2014 03:20 AM
Mattyg2
06-01-2004 02:46 PM
Quick Reply: Radiator Fan Not Functioning. Really Stumped.
