axels will not come out fo either side!
i had a bitch of a time jsut getting the axel nuts off got both off today and finally started to take em out after getting hub removed =/ driver side sllide out or so i thought the boot was riopped so it slid out with the bearings showing =/ and i cant get the other half of it out what the hell should i do? same with the passanger side there both stuck in!, i pull on the passanger side and it came out or so i thought the boot was still intact i just pulled the bearings away from the part that goes into the tranny =***( i need help!!!!!!!!!!!
you'll need a crowbar type tool for sure. don't yank on those things if you indend to use them again, it'll ruin them. there's a circular spring clip holding each one in, just get somthing to pry with dude. GOOD LUCK!
agreed, driveaxles on the tranny side have to be pryed and if the other side of them is still in the hub you need to slide the hub assembly out of the lower arm's bolt and away from the car in order to pull the whole driveaxle out... i think that made sense.. in my head at least, lol pm me if you need help
Tyson
Apr 22, 2004 06:20 PM
