Swap nightmare!!!!
Hey guys i recently swapped a jdm b18c into my 95 teg. TOday i went to fire her up and she was idling really rough and would barely stay running. I pulled it back in and found that my timing was ok and that it wasnt throwing any codes at me. I have checked and double checked all wiring and it is correct. Fuel system is a ok. I have just replaced the cap AND rotor with oem parts. What is my problem? Any ideas. coil is also fine i ran a voltemeter to it. Any ideas at all im desperate!!!
I seen a swap that had the Air Temp Sensor plug and the IAC valve plug swapped causing it to run very bad. The ECU was seeing 350 degrees and the IAC wasn't acting upor tripping a codes. Try swapping the 2 plugs.
I just replaced my coil and now it starts but it runs like ****. I checked my timing twice made sure it was @ tdc and everything checked out. It wont run above 3k rpm and idles like **** . what the **** is wrong w/ my car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 »</TD></TR><TR><TD CLASS="quote">cam timing is perfect it just wont start</TD></TR></TABLE>
wait, how do you know that the timing is perfect when you can't start the car, just because the cams are at TDC before you start it does not mean that they are going to stay that way with ignition.. did you ever adjust your idle? surely you have but better to ask than assume
...how'd they know i cry when i **********
if its almost stalling when its idol its probably wrong fire sequince...if not that, god hope its a bad spark plug if not that hope its a vacum leak, and not low compression.
as for the pole....wtf is this garbabe???admins please get rid of this bull crap!!!!
phaphon
11
May 11, 2010 09:41 AM
for making an open poll
