Extremly strong headbolt?
Old Apr 9, 2004 | 07:38 AM
sacredc0w69's Avatar
Default Extremly strong headbolt?
Well I'm ripping my motor apart to prepare it to get worked on and fixed.
We were gonna take the head off but we got like5 bolts off then we got stuck on one..
It broke 2 sockets, a 15mm and a deep socket
it was the only bolt we had trouble with 2...
any ideas how to remove it? we plan on getting impact sockets but not for a while
anyway i can loosen the bolt? lol
or is risking breaking more sockets the only way?
Old Apr 9, 2004 | 08:55 AM
JimBlake's Avatar
Default Re: Extremly strong headbolt? (sacredc0w69)
Tighten the other head bolts back up. That'll reduce the tension on the one you can't get. Maybe that'll work??
Old Apr 9, 2004 | 12:13 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sacredc0w69 &raquo;</TD></TR><TR><TD CLASS="quote">It broke 2 sockets, a 15mm and a deep socket
They should be 14mm shouldn't they?
Old Apr 13, 2004 | 08:33 PM
haha yea they are my bad sorry
But tightening the other ones back up wouldn't work, cuz we tried each headbolt from the start and that one and a few others we knew were gonna be a problem
Old Apr 13, 2004 | 08:41 PM
.bagged's Avatar
Default Re: Extremly strong headbolt? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Tighten the other head bolts back up. That'll reduce the tension on the one you can't get. Maybe that'll work??</TD></TR></TABLE>
Then loosen one at a time slowly..but keep rotating from bolt to bolt
Old Apr 13, 2004 | 08:46 PM
FatJoe's Avatar
Default Re: Extremly strong headbolt? (baGged93aCcord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baGged93aCcord &raquo;</TD></TR><TR><TD CLASS="quote">
Then loosen one at a time slowly..but keep rotating from bolt to bolt</TD></TR></TABLE>
exactly... do it in the right order so you dont warp the head and also only turn about 1/3 for each bolt in the same order every time... then you will have no problem... and good head...i mean A good head
Old Apr 13, 2004 | 08:50 PM
-RedneckDave-'s Avatar
Working
Default Re: Extremly strong headbolt? (FatJoe)
Use impact sockets as well they are stronger and are less likely to break. I have never broken any of the impact socket I have.
STROHM
Mar 12, 2009 09:03 PM
Xringmsp
Aug 10, 2007 02:02 PM
b18c inside
Jan 29, 2006 10:35 AM
1bar
May 12, 2004 10:33 PM
dfoxengr
May 11, 2004 11:16 PM
