Help needed, master cylinder or slave cylinder?
I think either my clutch master cyilnder or my slave cylinder is bad but i want some help narrowing it down
here's the symptoms:
-Bled the system, no visible leaks on lines, master or slave cylinder
-i drive it once, turn the car off, no problems.
- HOWEVER, the next time i start the car, after shifting gears once or twice, the clutch pedal is stuck to the floor, won't get out of gear until i turn the engine off..
I'm pretty sure it built air to the system, but i can't narrow it down..
ANY HELP IS APPRECIATED,
thanks!!
thanks!!
You may either need to bleed your clutch system again, but then again, you do my need to a master/slave cylinder. Try bleeding your clutch first and see what happens. If the same thing happens, then just replace both the master and slave cylinders. The parts aren't even that much, and they're real easy to install. Takes maybe an hour or so to do both
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">You may either need to bleed your clutch system again, but then again, you do my need to a master/slave cylinder. Try bleeding your clutch first and see what happens. If the same thing happens, then just replace both the master and slave cylinders. The parts aren't even that much, and they're real easy to install. Takes maybe an hour or so to do both</TD></TR></TABLE>
Agreed.
Since you have a 93 Prelude, I would change them out anyway. The parts are pretty cheap. Under $100 shipped for both. Changing the mater cylinder was the difficult part.
It's tedious and somewhat time consuming.
Good luck
Agreed.
It's tedious and somewhat time consuming.Good luck
ianae86
Mar 16, 2006 01:59 AM
infamousALLMTR
Apr 15, 2003 09:48 AM
